Results 1 to 4 of 4
Thread: CobraHeat Seat heaters switch hole size
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    Hi Guys,
    I'm planning on buying the Cobraheat seat heaters for my car...Click Here. I am currently trying to figure out my under dash switch layout. The seat heater switches will be among them. Can any of you tell me the size of hole needed for the switches so that I can make sure there's enough room for it in the layout.
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
    Elk Grove, NorCal
    In this picture of my test dash, it says 13/16". Sorry I'm not home to check the size but it is a nice snug fit with the locking locking tabs.
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Mark Eaton's Avatar
    Medford, Oregon
    I agree with Vspeeds, they are larger than standard toggles. I think I drilled to either 18mm or 20mm per the instructions.
    Jax Beach, FL
    One thing you might want to consider is using one type of switch instead of what just comes with each different thing. It makes for a cleaner installation. I used small round rockers for everything on my under dash panel, so nothing is sticking down. All the same style so they look the same. There are on/off, momentary contact, and three position (seat heaters) depending on the function.
