10-27-2020, 09:19 PM
#521
Had car out for short ride! Been to long. All went good with intake temp 70 and engine temp at 160, need to get tuned as new engine ( custom intake cam and lower compression, and lower intake temp). Running with out fenders and side panels to check on all engine parts, can not see or get to them. Need to put head lights on to be legalIMG_8765.JPG.
11-03-2020, 08:55 AM
#522
we need a video of the car running
11-05-2020, 11:24 PM
#523
Tuned at 716 RWHP. Need better intercoolers.
11-23-2020, 08:49 PM
#524
Made myself more work. Spun and went in ditch! Have parts on the way, is better than it looks.
AS always i am for safety parts, high back seats, harness, and cage.IMG_8778.JPGIMG_8773.JPGIMG_8776.JPG
11-23-2020, 10:22 PM
#525
Not gonna lie, that looks like a lot of damage.
11-24-2020, 01:49 AM
#526
Dreamer
Ouch!!! Hope the frame is still true!!
11-24-2020, 06:33 AM
#527
That sucks....sorry to see this after know how much work you put into this thing.
"Spun and went into the ditch" from slick roads, a little too much fun, or did something break?
I just go-carted mine this weekend and I thought of every one with big engines in these things. I only have a basic 302 in mine and barely getting on it both from starting out and shifting between gears I can cut the rear tires loose so I cannot imaging how squarely (yet very fun) these things are with a ton of HP.
Good luck, let us know how you make out.
11-24-2020, 10:15 AM
#528
Glad you are OK. Cars can be fixed.
11-26-2020, 08:31 PM
#529
Worked on car and is better than i thought. Bumper, brackets, radiator and fan gone. But custom bumper brackets and sway bar can be fixed.
The lower control arms are gone but the upper arms look good butt i will change all the control arms out. The custom fender brackets and lower water parts are a problem. Was going to change out intercoolers, i can get to them now!
PS rear control arms need to be changed out, will do both sides. Wheel put a small hole in my custom gas tank-- have not come up with a fix yet.IMG_8783.JPGIMG_8782.JPG
12-09-2020, 10:29 PM
#530
Front is ready for new parts, fedex to bring FFR parts 12/10. So will start back together!!IMG_8786.JPG
12-10-2020, 06:57 AM
#531
1932
Glad to hear it was better than it could have been. Good luck with the rebuild
01-07-2021, 09:05 PM
#532
FFR is shipping most of the parts (some on back order) i need to work on car! Making and molding parts is more fun the first time.
Working on new intercooler, building water and air tanks.IMG_8790.JPGIMG_8791.JPG
This is the difference inside of coolers.IMG_8793.JPGIMG_8794.JPG.
Any ideas on fixing gas tank? Very hard to get out. Use argon to get o2 out and weld?IMG_8797.JPG this does not sound good!
wrp liked this post
01-07-2021, 10:04 PM
#533
01-12-2021, 12:01 PM
#534
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
wrp liked this post
01-20-2021, 10:39 PM
#535
Need end plats with 2.5 tube to be done with one new intercooler, other is half done.IMG_8799.jpgIMG_8800.jpg
Still needing some parts for control arms.
wrp liked this post
02-02-2021, 10:03 PM
#536
New control arms and spherical bearings in on right rear, IMG_8804.JPG The bearings had to be installed from the inside of arms, snap rings to the outside to fit ears.
Can not put new intercoolers on till i have wheels and tiers, then build new pipes and brackets.IMG_8805.JPG
Still waiting on some parts.
02-06-2021, 11:52 PM
#537
wrp liked this post
02-25-2021, 10:30 PM
#538
Made new lower radiator tubeIMG_8813.JPG you can how it fitsIMG_8825.JPG and other parts.IMG_8818.JPG
wrp liked this post
03-15-2021, 10:25 PM
#539
Working on fender brace and wheels and tires are on the way. Still need to mount intercoolers after i get front wheels for clearance. Had problems with hood latch hitting the top of radiator, so as i don'tIMG_8828.jpgIMG_8830.JPG need cap on radiator, it is on small tank, i cut it off.
wrp liked this post
03-30-2021, 10:22 AM
#540
wrp liked this post
04-05-2021, 10:04 PM
#541
OK, we are all most ready for alignment. I set toe close so will be good to drive to shop.IMG_8846.JPGIMG_8850.JPGIMG_8852.JPG
04-14-2021, 08:16 PM
#542
Post Thanks / Like - 0 Thanks, 6 Likes
04-14-2021, 08:27 PM
#543
![](https://thefactoryfiveforum.com/attachment.php?attachmentid=49655&d=1452637671)
1932
Impressive!
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
04-27-2021, 10:46 PM
#544
Got new bumper on. Different company so had to rework bracketsIMG_8861.JPGIMG_8865.JPGIMG_8866.JPG
05-27-2021, 10:22 AM
#545
Had ac pump go out == lot of work to replace with ford coyote and to fit belt.IMG_8875.JPGIMG_8876.JPG
wrp liked this post
05-27-2021, 10:27 AM
#546
Had 4-wheel alignment. 2015-17 shelby gt350R
Car wants to duck walk under power. going back for checkup. Any thing to look for??
05-27-2021, 11:30 AM
#547
After a couple of close calls, I am looking at the front bumper now. Which company did you go with?
05-27-2021, 02:37 PM
#548
The new one is UP, other was bob drake. I liked the bob drake better but was not available. Both are stock 33.
05-27-2021, 03:27 PM
#549
1932
You can get similar ones at Speedway Motors too.
Jim
12-01-2021, 09:22 PM
#550
Had problem with steering rack- lots of play on right side. Read in pickup forum about right side bushing working out. That was the problem with my manual rack.
Wet cloth around rack and weld, all good.
Metal is one inch pipe.
The bushing was good just put back in and new part to keep in, no lose of steering movement.
01-02-2022, 09:35 PM
#551
Changed the wilwood front brake kit (140-12048) front pads to Hawk DTC 30 (HB645W.490) )
I am very happy with with braking now.
01-09-2022, 11:18 AM
#552
1932
I am usually a function over form guy, but I do have to say that I really like the look of the Wilwood front brakes.
02-08-2022, 07:21 PM
#553
Rolled Over 6000 miles and adding.
02-08-2022, 07:44 PM
#554
I just broke 3,000 miles. I am doing a Calistoga lunch run this weekend just to put some miles on the hot rod.
