Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Front Brake Fasteners
    Vero Beach FL
    Hi Everyone.
    I am working on the front brakes. I assembled all the components and I am cleaning up to paint via POR-15 caliper kit. As I organized, I do not see the bolts to connect the calipers to the hub assembly. I have pored over the manual and do not see the fastener required. I see a picture in the manual. But I can’t figure it out.
    Anyone know the fastener? Size, shape, length? Do I need a washer or nut?
    Thx. Tom
    Mk4 #10605 Ordered 5/28/2022. Received 3/18/2023
    Build Thread https://thefactoryfiveforum.com/show...-Roaster-Build
    Vero Beach FL
    I am trying to figure out what fasteners are used bolt the caliper on. Any idea?
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    What calipers are you using? The Wilwoods came with the mounting bolts in the box with all the other brake parts.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
  4. Thanks Gizmosrcool thanked for this post
    Norton, MA USA earth
    M12x1.75 35MM long. they are 12 point heads.
    If you want to see a pic follow this link to McMaster-Carr
    https://www.mcmaster.com/93700A228
  6. Thanks Gizmosrcool thanked for this post
  7. #5
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    For the front brakes FFR supplied, they should have also supplied the bolts. Have you scoured the fasteners box for four, rather large bolts?
    Matt
    My build thread here
  8. Thanks Gizmosrcool thanked for this post
  9. #6
    Vero Beach FL
    I think I found it. Take a look. Michael Everson tickled a brain cell with the 12pt comment. These are 12pt, fit the caliper, and 35mm long. For some reason these did not jump out to me.
    Do I use a washer or anything? Or just some blue locktite on it and tighten it up?
    Thx for the help. Tom
  10. #7
    Jul 2020
    Spencer, MA
    You don't need washers on flange head bolts. Definitely blue loctite.
  11. #8
    But maybe, for now, skip the loctite and hang a piece of tape or some other reminder to do it later. As you probably already know the first install is not always the final install.
