Results 1 to 11 of 11
Thread: Pics of outside coolant tubes
    Jan 2024
    I know the GTM forum isn't very active anymore, but....
    If anyone seeing this did the outside the frame coolant tubes, post up pics of your setup! Would like to see some different routing ideas.
    Calling Crash here too.... as I understand he pioneered this mod.
    Sal Mennella
    Unfinished GTM #30 FFR - in progress!
    Roadster 5132 - sold
    Mar 2021
    SE WI Kettle Moraine
    My chassis is the 818 and I have installed a Ferrari Dino replica body. The Dino body mounts higher than the 818 giving me the opportunity to run the coolant tubes below the rocker panels.
    The hose bibs come up into the body near the F & R wheel wells. This made routing into the front compartment neater and opened up the footwells. Obviously better heat exchange and less heat into the interior. I would have used finned extrusions but could not find that configuration. I welded mount bosses and drains into the bottom of the tubes.
    Semi gloss black makes them less obvious.
    jim
    Apr 2021
    You probably have Gen I. Mine is Gen II, so it's slightly different. (Idea inspired by Crash)
    Senior Member beeman's Avatar
    Indiana
    I'm running them just inside the rear aluminum firewalls, in enclosed insulated aluminum housings. It's the most direct path from and to the water pump.
    GTM #304 LPE 525hp LS3
    Jul 2014
    Quote Originally Posted by beeman View Post
    Any concern with the passenger side going right under the fuel tank? Or do you plan on insulating it with something?
    Indiana
    Sorry about the confusion, the fuel tank was pulled forward when I took that Pic, the firewall will separate the coolant line from the fuel tank...
    Jul 2014
    Ahhhhhh gotcha.
    May 2016
    But the other side of the firewall is the passenger compartment.
    Indiana
    Quote Originally Posted by doug_porsche View Post
    Disregard anything other than the coolant pipes traveling along the rear aspect of the passenger compartment behind the seat right in front of the firewall.
    This chassis is slightly modified, the B-pillars are moved forward.
    San Diego
    Sorry I haven't posted any more pics in this thread. It is near impossible to see anything on a completed car. Best pics I have I have already posted in other threads.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Apr 2021
    Since it was posted in my build thread, I'll do the honors. Assuming the routing hasn't changed.
