Thanks Thanks:  4
Likes Likes:  2
Results 1 to 14 of 14
Thread: Wilwood balance bar adjuster for brakes
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    I’m trying to figure out where to mount the adjusting knob. I don’t want it on the dash proper for aesthetic reasons. I’m a large guy and the driver side foot box is already tight. I’m thinking I could mount it under the dash on the passenger side. I could also mount it on the transmission tunnel but that feels busy. I have also thought about mounting it in the glove box. It won’t be used a lot but it is still accessible. Other options?
    Thanks!
    Dan
    Mk4 complete kit arrived 10 May 23
    Current BOM
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    How about on the 2x2 below the dash, near where the manual suggests placement of the inertia switch? I'm curious why folks install these knobs, though. If you dial in your brakes via the balance bar when in go kart stage, do you need to adjust them again, or with any frequency? I guess it allows you to dial it in while driving?
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  3. Thanks danmas thanked for this post
    Jan 2019
    Mead Colorado
    I think I’m going to copy blitzboy and install a center console stereo there.
    I’m installing it because Gordon Levy of Levy racing said I should and since I have his monster brake setup it make sense to do it. I think if you track the car, and I might, it’s useful to fine tune the brakes. And it’s a fun puzzle to solve.
    Current BOM
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    Hey Dan, I’m adding one in as well. I plan to put mine behind the primary dash on this secondary dash, along with my headlight switch and a few other “hidden” controls too.
    https://thefactoryfiveforum.com/albu...hmentid=197749
    I’m not sure I would put it in the passenger side, since if this does get adjusted without the driver knowing, then it becomes a safety hazard. Just throwing out my thoughts and idea.
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
  6. Thanks danmas thanked for this post
  7. #5
    Jan 2019
    Mead Colorado
    Quote Originally Posted by ydousurf View Post
    Doug
    Doug,
    Thanks for this. You are spot on. I want it in a place where only I can adjust it. Really appreciate this.
    As an aside, I’m right down the road from you if you ever want to see my build or show off yours….
    Dan
    Current BOM
  8. Likes ydousurf liked this post
  9. #6
    Member Wizbangdoodle's Avatar
    Nov 2023
    I've got one of these too and my plan was to mount it under the dash just to the right of the steering wheel. Haven't checked fit there yet, but I think it will work.
  10. #7
    Maricopa AZ
    Mount it on the U panel at the front of the tunnel. Out of the way and easy to reach.
  11. Thanks danmas thanked for this post
  12. #8
    Feb 2019
    Greality, Colorado
    Quote Originally Posted by danmas View Post
    Doug,
    Dan
    Yeah Dan, we’ll have to get together and do a show & tell & talk sometime soon! I actually just began working on mine again just these past couple weeks. I recently added remote battery terminals and a power cut-off switch in the trunk. This past weekend I added my grab bar on the dash and in the process of getting all the wiring all sorted out. I’m still in the pre-construction & custom modification phase. Which means I have a lot to do still. Planning to have it as a driver this coming summer. And I need to bring my build thread current too. Late as always. Anyway, carry onward with build fun…
    Doug
  13. #9
    Oct 2020
    Albany, NY
    Quote Originally Posted by gbranham View Post
    I am as of right now not installing one on my second build for this reason. You definitely fine tune it after while on the road and it makes this task much easier. BUT, like you say for everyday driving you never touch it again. The other thing is though if you were to auto cross or do any track days the opposite would be true. Having the ability to adjust remotely would be a game changer. The nice thing is it would not be that hard to "retro fit" one in later. I might still do it but it's a $150 I just don't want to spend right now for something I may not ever use.
    But saying that don't be surprised if I install one....... I'm a mess
    This is what I did last time.
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
  14. Likes danmas liked this post
  15. #10
    I had one in My MkII. Yes you get it dialed in pretty much in the first day or 2. And, if nothing ever is changed w/ tires or suspension, that would probably be good enough. But even that 1-2 day process is a heck of a lot easier if, between stops, all you have to do is twist a knob vs finding a place to get off the road and park. Also I did a lot of autocross and getting the brake bias just slightly more to the rear than you want on the street, made the entries in to hated tight corners suddenly a dream. I often made a 1 click adjustment between runs.
  16. #11
    May 2018
    Milwaukee, WI
    Thanks!
    Dan
    Just to add to the conversation, I ended up putting my brake bias knob under the dash on the center panel along with a battery cutoff switch. It is easily accessible (assuming I ever really use it) and looks relatively clean. Just another option to consider.
    I wrote about it a bit in my build thread: https://thefactoryfiveforum.com/show...l=1#post559614
    BUILD THREAD: The Brew City Cobra
    Current Build: MK4 Complete Kit, Delivered December 2021; First Start November 9, 2022; Go-Cart November 23, 2022; Carbureted 427W, TKX, IRS
  17. Thanks danmas thanked for this post
  18. #12
    Dec 2021
    Flower Mound TX
    Here's where and how I mounted mine.
    I used a Tilton 90 degree adapter to make routing the cable easier.
  19. #13
    Jan 2019
    Mead Colorado
    Hi Jesse, Yes, that’s where quite a few people suggest (Gordon and BrewCity et al.) However, thanks to your build thread I think I’m going to put an entertainment console there. Perhaps I can hang it out of the driver side panel on that entertainment console. I think it will depend on which touch screen I put there. I have seen some single din devices that have a tablet like screen out the front. I will make up something in cardboard and see how it fits. Thanks for the ideas gang.
    Dan
    Current BOM
  20. #14
    Oct 2020
    Albany, NY
    What Mike showed you is the the left of the steering column. If I was to put one it that's where I would put it too.
