Thanks Thanks:  29
Likes Likes:  233
Page 12 of 12 FirstFirst ... 2101112
Results 441 to 450 of 450
Thread: Mike in Texas FFR Roadster Build - She's Alive! (Again)
  1. #441
    Dec 2021
    Flower Mound TX
    Had a productive couple of days. Yesterday my wife helped me and we dropped the "somewhat new" engine and trans back into the car.
    Tip of the day for you, if like most here you're using a HF 2T hoist it doesn't quite have enough reach with the body on the car. Had to make an extension from some 2x2 tubing to extend the boom about 18" or so. However, now the rear of the hoist gets really light when a SBF/Tremec is hanging off the end so to be safe we added some ballast to the rear of it.
    All of this worked great until we tried to move it. The two of us were barely strong enough to move it and then it was in very small increments. We managed to get it roughly in position and ended up moving the car during the drop in as it was much easier. From start to finish it only took about an hour to get it dropped in. A good quality leveler is an absolute must.
    Today I dropped on the stack EFI on and torqued it down. Installed the fuel lines, power steering pump, PS lines, throttle cable, and valve covers. Under the car installed the transmission support frame, transmission bolts, and driveshaft. Topped off the Tremec with fluid so it's good to go.
  2. Likes Rebostar, Fman, ydousurf liked this post
  3. #442
    Senior Member Rebostar's Avatar
    Jan 2024
    Looks good! VROOM VROOM tomorrow?
  4. #443
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    It's been bitter cold down here in Texas the past week, sometimes all the way down in the low 40's in the mornings. Without a heater in the garage have to wait on some warmth to get going
    Hah..."bitter cold". We had lows at 12 degrees this week. My neighbor is from Lake Jackson, Texas...on the Gulf. He was a hurtin unit this week.
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  5. Likes Mike.Bray liked this post
  6. #444
    Dec 2021
    Flower Mound TX
    Over the last couple of days buttoned everything up on the new and improved engine and fired it up. Locked out the timing to 20 degrees in the ECU and set the distributor, borrowed my wife's eagle eyes to make sure we got it on the mark. One thing I did was re-clock the distributor to a better orientation with the Borla stacks. Now all of the plug wires are the wrong length so going to redo them this afternoon.
    https://youtube.com/shorts/Z6fe29wFXuM?feature=share
  7. Likes PNWTim, Rebostar, Fman liked this post
  8. #445
    Dec 2021
    Flower Mound TX
    Since I re-clocked the distributor to work better with the Borla stacks I needed to redo the plug wires. Went with these 9mm wires from Ford Racing. I think they're really nice in that they are cut to length and numbered. Got the blue to match the car.
  9. Likes RJD liked this post
  10. #446
    cv2065's Avatar
    Dec 2017
    Looks and sounds great Mike!
  11. Likes Mike.Bray liked this post
  12. #447
    Senior Member Nigel Allen's Avatar
    South Australia
    Fancy!
    Gen1 Coyote / TKO600 / IRS
  13. #448
    Quote Originally Posted by gbranham View Post
    Yeah! I guess it's all in perspective! After daily highs in the low teens and even some single digit nights last week we got above 40 degrees yesterday so I threw the shop doors up and enjoyed the "balmy" temperatures
    Oct 2020
    Albany, NY
    Bitter... lol
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
  15. #450
    Dec 2021
    Flower Mound TX
  16. Likes maclonchas, Chainsaw liked this post
