![Very Cool Parts](https://thefactoryfiveforum.com/attachment.php?attachmentid=40527&d=1428867450)
0
I've been working on a few details one of which was the O2 wiring that was left hanging since the go-cart event. The right cable was very close to not being long enough even after reworking the harness to lengthen it per the Ford Racing instructions. I found a path where I could utilize the mounting features on the harness connector and a screw on the Infinity power Module for a cable clamp. I made a simple bracket and drilled out a couple of foot box rivets to reuse the holes to mount it. The right side is shown here.
The left side had ample cable length and the mounting is similar to the right except the bracket is a little more complicated. I mounted it using #8 screws and nutserts in the foot box sheet metal for both the bracket and cable clamp.
2015-06-17 14.42.12d.jpg 2015-06-17 14.45.03d.jpg 2015-06-17 14.47.27d.jpg 2015-06-17 15.04.55d.jpg 2015-06-17 14.47.49d.jpg
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
