0
0
Strong fuel smell in garage
I am dealing with a strong fuel smell in the garage and hope to deal with it as others have with a charcoal canister to capture the fuel vapor at the vent hose coming from the tank. I did have a leak at the sender seal and fixed that so hopefully this canister will do it.
I have this fuel vapor canister and bracket and intend to mount it near the fill tube in the PS wheel well as high as I can. The two large ports in the center are going to be left open, the smaller one on the side will connect to the fuel tank vent tube, the other one a little larger on the side is normally connected to the manifold vacuum port but I'm going to leave it open.
Anything I'm missing, any suggestions?
