Redbone Has Graduated / The Official Dark Side Build Thead
The Redbone Roadster
What Redbone Means:
The word REDBONE is a Cajun term for a person of mixed-race, which the REDBONE BAND adopted to signify their mixed ancestry...The combined ethnic groups include Native American, African and European so these people are unique because they are the culmination of many cultures...Since my car is also made up of mixed origins, Truly A Louisiana Gumbo, it is only fitting that it be given this name since it is neither Ford nor Chevy nor Shelby, but something totally different and unique.
https://en.wikipedia.org/wiki/Redbone_(ethnicity)
Last Go-Kart Drive Before Block Debacle:
https://youtu.be/PCngiKoopkA
New Engine Block Arrives:
https://youtu.be/IGYtX-3p7xk
Friends Help Pull The Leaky Block:
https://youtu.be/Vhbftk4AP4k
New Mill Gets Installed:
https://youtu.be/-nVDzIjSjh8
What The Car Looked Like As A Red Gel Coat Driver:
https://youtu.be/CaRlqMmKIzk
Our Final Build Thread Video:
https://youtu.be/9WEe6-wdNtA
Here Are The Specs For Our Build:
1. 383 Small Block Chevy (Dart SHP Block) 10-1 Somewhat Pump Gas Friendly Compression Ratio!
2. Eagle Internally Balanced Rotating Assembly With 6" H-Beam Rods With Floating Forged Flat Tops.
3. Dart Iron Eagle 215 CC Heads with 2.05 Intake & 1.60 Exhaust Valves.
4. Harland Sharp Roller Rockers & Other Go Fast Goodies.
5. Comp Cam Extreme Energy 288 Hydraulic Roller Tappet Cam
6. Edelbrock AVS 800 Feeding A Weiand 7530 Team-G Single Plane Manifold.
7. Schoenfeld IMCA Modified Headers & They Really, Really Fit, But Stuff Had To Move A Bit!
8. New Old Stock Corvette ZF 6-Speed Transmission With Hydraulic Clutch. (.75 5th & .50 6th Gear Over Drives)
9. Standard Front End Set Up With Mustang Brakes & Forte’s .75” Sway Bar.
10. Standard 3 Link Moser TSD 500 Rear (Dana 44) With 3.73 Gears & Explorer Brakes.
11. The wheelbase has been shortened by .875" to better center the rear wheels within the wheel arches and improve pinion angle adjustment.
REDBONE / The Band:
The Vasquez-Vegas brothers were of Yaqui, Shoshone, and Mexican heritage...They began by performing and recording surf music as the Vegas Brothers, later as the Crazy Cajun Cakewalk Band, where they performed throughout the 1960s at venues on the Las Vegas Strip...In addition, the band often alluded to Cajun and New Orleans culture in their lyrics and performing style.
https://youtu.be/OnJqFrVD3uE
https://youtu.be/7jUii4gFGZQ
https://youtu.be/kECS4CeitQw
https://youtu.be/yaC_kX_kWs4
Post Thanks / Like - 0 Thanks, 5 Likes
