From donh5599:
is it ok to cut off the quad shock mounts and upper control arm mounts to dress it up a bit?
From donh5599:
YES, it has been done many times when using the 3-link assembly from FFR. Also the spring mounts can be removed if using coil-overs.
Doug
I can see removing the quad shock mounts as long as you're upgrading/using a set of coilovers.
But I don't know how you could remove the upper control arm mounts and actually use the rearend in a car. How would the power be transferred to the chassis if the control arms aren't attached to it?
Will
FFR MK III picked up 9/24/05 Roller 9/28/05 First start & go-cart 11/28/05 red w/white stripes, PC Chassis, heat/defrost, FFR 15's, pwr footbox vents, radio delete, dual quad 427W, 4 link w/3.27's, Koni's all around, Gen 1 rag top, snapless tonneau, Herb's door panels, NRC rear discs, Breeze head rest, ********** emblems, Paint by Gino's in Rowley, MA
2011 ffcars.com calendar Cover Car Yes, that's me in the avatar with Dave Smith in front of my roadster at the '06 FFR Open House!
Thanks for the clarification.
Clearly my set up is a 4 link and they are most definitely needed for that arrangement!
Hopefully, the OP was asking about a 3 link...
Will
