Results 1 to 13 of 13
Thread: Tools needed to build a FFR kit
    Senior Member subyrod's Avatar
    Utah
    So, I tried searching the website and other forum posts first, but didn't see anything that fit what I'm after.
    I'm very interested in building the new Suby donor kit that was announced and am active in that forum. But, what I was hoping to find is a basic list of tools I'll need. This way I can start slowly acquiring these tools for the project. I have a friend that is building a Cobra and have watched the DVD FFR had out a few years back (geez, must have been 5 years ago) and I tooled around the FFCobra forum for awhile a couple years back, so I understand the basics of what the process is to build a kit. But now that this suby kit is coming out and its in the price range that is doable and I already have the donor car that is getting up there in years, I wanted to start putting my game plan in place to DO THIS!!!!
    Torque wrench (what range of ft-lbs?)
    Hand riveter
    Wrenches/sockets/screwdrivers
    jack stands
    jack
    pliers/wire cutters
    sheet metal sheers?
    Theoretically no body work stuff (Dave said the plan is to try and have colored gel coats for a no paint kit).
    What else? I know I'm missing stuff.
    Helicopter Wrench-Bender ChopperJustin's Avatar
    St. Georges, DE
    Just off the cuff:
    lots of 1/8 and 3/16 Cleco's
    A good set of hand files
    Center Punch (spring loaded is nice if you can sit still)
    A couple different sized rubber mallets
    A nice 1/4 air drill (shop air makes things easier) or battery drill
    90 degree angle grinder (again, shop air)
    Safety-wire pliers (I safety-wire everything, it's an aviation thing)
    "Gravity, It's The Law"
    Utah
    Good stuff, thanks ChopperJ.
    Here's the bulk of the tools I used:
    Safety glasses
    Work Gloves
    100+ Cleocs
    Cleco pliers
    Files
    Vice
    Clamps
    Torque wrenches (0-90 ft/lbs is good for most but for wheel nut you need 250 lbs)
    36mm deep socket for axle nut
    4 Jack Stands
    Floor Jack
    Engine hoist, load leveler & chain
    Jig saw with a metal blade
    Hack saw or jig saw with a sheet metal blade
    Fuel/brake line bender
    SAE and metric socket set with deep sockets
    Good set of box wrenches
    Standard and Phillips head screwdrivers
    Standard Allen wrench set
    Needle nose pliers
    Snap ring pliers
    Vice Grips
    Pop rivet tool with 1/8 and 3/16 heads, if you don't have a compressor, I recommend a rivdrill also.
    Electric Drill
    Drill bits (3/32, 1/8 - use #30 wire size drill for rivets, 9/64, 3/16, 7/32, 5/16, 7/16, 1/2)
    Caulk gun - Silcone Caulk, Seam Sealer (available from NAPA)
    Rubber Mallet
    Razor knife & single edge razor blades
    Wire stripper/crimping tool
    Sissors, (Carpet shears if your going to do the trunk)
    A variety of hole saws 7/8, 1 1/4 and 2 1/4 hole saws
    Tape measure or straight edge ruler/T-square
    Soldering iron
    Electrical solder
    Heat shrink insulation
    Wire Brush
    Thread locker (both blue & red)
    Brake line flairing tool
    CV Boot Crimping tool (if you have IRS)
    Magic Markers
    Nice to have category:
    Air Compressor
    Dremel with small cut off wheels
    Rivet spacer fan
    90 degree drill attachment tool
    Speed brake bleeder
    Fuel line quick disconnect tool
    Heat Gun
    Bruce
    Utah
    Dang Sharkx! Thanks for taking the time to put this list together. Awesome!!!
    Senior Member chrisarella's Avatar
    Clearwater, FL
    Question: which type of cv boot tool to get?
    Mark IV Roadster #7679
    Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
    Copperhill, TN
    Add a 90 degree drill, or adapter.
    Junior Member Hondros's Avatar
    Dec 2013
    Greensboro, NC
    Great list guys. I can begin accumulating the necessary tools I am lacking. Hopefully I can borrow or rent any tools like the large torque wrench.
    Any recommendations on a nice size compressor that will fit in tight garage and still get job done without running 24/7?
    Senior Member AZPete's Avatar
    The Factory Five manual for the Mk3 I built included this at the end of the required tools list: The stuff between your ears.
    It's not on the current tool list, but still needed. Most guys on the forum are using it, a few not.
    Senior Member DaleG's Avatar
    Mar 2013
    Ditch the hand riveting tool and get a Harbor Freight pneumatic riveter and a small air compressor; you'll get your car finished 6 months sooner!
    Dec 2013
    Greensboro, NC
    Quote Originally Posted by DaleG View Post
    I found a great deal online for a 26 gallon craftsman compressor for 199 bucks. I think this will be good size to run anything I will need while building this car.
    Massachusetts
    What is the min and max reach on the 1/8 and 3/16 cleco's? I have my 818s kit but no rivets yet.
    Member M3ichael's Avatar
    Salinas, CA
    Quote Originally Posted by sharkx View Post
    Safety glasses
    Work Gloves
    100+ Cleocs
    Cleco pliers
    Files
    Vice
    Clamps
    4 Jack Stands
    Floor Jack
    Needle nose pliers
    Snap ring pliers
    Vice Grips
    Electric Drill
    Rubber Mallet
    Soldering iron
    Electrical solder
    Wire Brush
    Magic Markers
    Air Compressor
    Rivet spacer fan
    Speed brake bleeder
    Heat Gun
    Bruce
    Bumping thread for updates if necessary. Does the MK4 build require any tools not listed above?
