Results 1 to 35 of 35
Thread: Factory Five Type '65 Coupe Registry
    IMPORTANT! DO NOT POST TO THIS THREAD
    Welcome to the Factory Five Type '65 Coupe Registry!
    This is a special forum, which showcases YOUR Factory Five Type '65 Coupe!
    There is only one ACCEPTABLE way to post to this forum, and that is to fill out THIS FORM.
    The form is for you to describe YOUR Factory Five Type '65 Coupe.
    This thread is for ALL Factory Five Type '65 Coupes! If you have a build in-progress, that's OK! Just don't put a completion date. All Registry Entries without a completion date will be considered still under construction. You can update your registry entry just like any other post on TheFactoryFiveForum.com.
    Warning: posting directly to this thread (not filling out the form) will result in your post being deleted.
    So if you own a Factory Five Type '65 Coupe feel free to fill out THIS FORM and submit it to the Registry!
    Senior Member snakebit31's Avatar
    Virginia Beach, VA
    Factory Five Type 65 Coupe Registry
    FFR Number
    10000189
    Delivery Date
    Completion Date
    ''Mark''
    TheFactoryFiveForum.com user name of current owner
    snakebit31
    Current Owner Name
    Robert Twine
    Former Owner Names
    State of Completion When Bought
    New Kit from Factory Five
    Color - Body
    Blue
    Color - Stripe
    White
    Engine Displacement
    331
    Engine Induction
    Injection
    ''Other'' Engine Displacement
    Transmission
    TKO 500
    ''Other'' Transmission
    Rear Gear Ratio
    Other
    ''Other'' Gear Ratio
    2.73
    Differential Type
    Limited Slip
    ''Other'' Differential Type
    Rear Suspension Type
    3-Link
    Shocks
    Bilstein
    ''Other'' Shocks
    Suspension ''Width''
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Roll Bar Type
    None
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Heater
    • AC
    • Trunk Battery Box
    • Backup Light
    • Wipers
    Regional Location of Build
    Southeast US
    Detailed Description of Custom features
    Image Attachments
    Louisiana
    FFR Number
    2708
    Delivery Date
    Completion Date
    ''Mark''
    EJ III
    Current Owner Name
    EJ Bourque
    Former Owner Names
    Color - Body
    Dark Green
    Color - Stripe
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    Levy 5-link
    Shocks
    Koni Double Adjustible
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Trunk Battery Box
    • Overriders
    • Wind Wings
    • Sun Visors
    South Central US
    Image Attachments
    FFR Number
    564
    Delivery Date
    Completion Date
    ''Mark''
    CHOTIS BILL
    Current Owner Name
    Bill Lomenick
    Former Owner Names
    Color - Body
    red
    Color - Stripe
    gold
    Engine Displacement
    427
    Engine Induction
    Stack Injection
    Transmission
    Other
    SS700
    Rear Gear Ratio
    3.55
    Differential Type
    Torson
    IRS
    Shocks
    QA1 Double Adjustible
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Roll Bar Type
    None
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Backup Light
    • Front Splitter
    • Custom Mirrors
    • Wipers
    • Custom dash
    • Wind Wings
    SoCal US
    Type 65 Gen 2 complete kit with IRS, Ford Racing all aluminum 427 engine, MegaSquirt injection, VCP stack injection, Raptor polished stainless exhaust system, Kessler SS700 transmission, Quick Time bell housing, Ram twin disk clutch, Breeze front mount battery box, Billet Specialties True Track serpentine belt drive system, Forte drive shaft loop and hydraulic clutch slave cylinder, 6 piston Wilwood front brakes, 4 piston Wilwood rear brakes, Goodyear Eagle F1 GS-D3 tires, stainless steel brake and fuel lines,
    Image Attachments
    Dec 2012
    Prosper Texas
    FFR Number
    F5R1000285CP
    Delivery Date
    Completion Date
    ''Mark''
    DcoupeMan
    Current Owner Name
    Myself
    Former Owner Names
    Color - Body
    Coper
    Color - Stripe
    none
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    Other
    TKO 3550
    Rear Gear Ratio
    3.73
    Differential Type
    Torson
    3-Link
    Shocks
    Bilstein
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Optional Equipment
    • SAI Mod
    • Wipers
    South Central US
    Image Attachments
    Junior Member mtcoriel's Avatar
    21035 S. Ron Lee Dr. Shorewood,Il 60404
    FFR Number
    F5R1000517CP
    Delivery Date
    Completion Date
    ''Mark''
    mtcoriel
    Current Owner Name
    Michael Coriell
    Former Owner Names
    Color - Body
    none
    Color - Stripe
    none
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    TKO 500
    Rear Gear Ratio
    3.31
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    Koni Single Adjustible
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Heater
    • AC
    • Custom dash
    Northern Central US
    Image Attachments
    Senior Member Austexican's Avatar
    Mar 2013
    Texas
    FFR Number
    F5R1000387CP
    Delivery Date
    Completion Date
    2009
    ''Mark''
    Austexican
    Current Owner Name
    Former Owner Names
    Bill Shaw
    Car Was Complete
    Color - Body
    Blue
    Color - Stripe
    Silver
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    upgrade to IRS in 2014
    Shocks
    Bilstein
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    255
    Tire Size - Rear
    315
    Optional Equipment
    • Heater
    • AC
    • Trunk Box
    • Trunk Battery Box
    • Backup Light
    • Custom Mirrors
    • Wipers
    Northeast US
    Ford 302 V8 estimated 400 hp. Type R valve covers, Weiand intake, FAST EZ EFI, Elgin E1017P cam, AFR165 aluminum heads, titanium header wrap. Canton aluminum coolant overflow tank with sight gauge. Leather seats. Autometer instruments. AC & heat. Wilwood brakes, FR500 wheels with Cobra hub emblem. Ron Francis wiring.
    Image Attachments
    FFR Number
    F5R1000525CP
    Delivery Date
    Completion Date
    ''Mark''
    conway witten
    Current Owner Name
    conway witten
    Former Owner Names
    Color - Body
    Royal blue
    Color - Stripe
    white
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    4.10
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    250
    Tire Size - Rear
    315
    Optional Equipment
    • Radio
    • Heater
    • AC
    • Wipers
    • Wind Wings
    Southeast US
    302 Ford with pocket ported heads, Comp Cams roller cam, Gear drive cam drive, Pretronix distributor, 650 Double pumper, dual plane Hi rise manifold, Comp Cams pedestal rocker arms, Steel 28 lb flywheel, blow proof clutch, Quick Time blow proof bell housing, Steda shifter, 4.11 ring and pinion, 250/40/17 front tires, 315/35/17 rear tires, 17/9 front wheels, 17/10.5 rear wheels, FFR air conditioning and heat, FFR wiper kit, FFR carpet kit, paint Sikkens Royal blue, with white stripes.
    Image Attachments
    FFR Number
    116
    Delivery Date
    04\2003
    Completion Date
    03\2007
    ''Mark''
    turbodon
    Current Owner Name
    Don Vaught
    Former Owner Names
    None
    Color - Body
    Go Mango
    Color - Stripe
    Silver
    Engine Displacement
    410
    Engine Induction
    Port Injection
    Transmission
    Tremec 3550
    Rear Gear Ratio
    3.27
    Differential Type
    Tru-Trac
    IRS
    Shocks
    Bilstein
    Pin Drive Rear, Standard Front
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Optional Equipment
    • Heater
    • AC
    • Wipers
    NorCal US
    Detailed Description of Custom features[INDENT][I] Frame mods, Adjustable steering height, Width Pin Drive Rear Standard front, Door bars, split dash, Wilwood 6 piston front, Wilwood rear, 22 gal fuel cell, Kirkey seats, sway bars, custom Burns Stainless side exhaust.
    Feb 2014
    FFR Number
    F5R100047CP
    Delivery Date
    Completion Date
    ''Mark''
    DaytonaCoupeDean-o
    Current Owner Name
    Dean Robidoux
    Former Owner Names
    Color - Body
    resin red
    Color - Stripe
    Engine Displacement
    4.6 DOHC
    Engine Induction
    Injection
    Transmission
    Other
    Tremec 3650
    Rear Gear Ratio
    3.27
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Radio
    • Heater
    • AC
    • Foot Box Vents
    • Backup Light
    • Glove Box
    • Wipers
    • Sun Visors
    Northeast US
    Hi, I'm in north central Ma.. Just a FYI, you have a lot of compulsory questions for a guy who just picked up his dream car, and may not have all the parts or may not have decided on things like color. Other than that I'm excited and disappointed. I started my build on the 8th of June and in a stall, my spindles and front shocks were back ordered. I'm waiting on my Wilwood brake system, and I don't have my rear axle yet.
    Image Attachments
    Senior Member Fluge's Avatar
    Ontario
    FFR Number
    434
    Delivery Date
    Completion Date
    ''Mark''
    Fluge
    Current Owner Name
    Fluge
    Former Owner Names
    Color - Body
    Guardsman Blue
    Color - Stripe
    Pearl white
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    TKO 500
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Pin Drive
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    275
    Optional Equipment
    • Power Brakes
    • SAI Mod
    • Heater
    • AC
    • Foot Box Vents
    • Trunk Battery Box
    • Backup Light
    • Custom Mirrors
    • Wipers
    • Custom dash
    Eastern Canada
    Image Attachments
    Superannuated Member
    Virginia
    FFR Number
    F5R1000533CP
    Delivery Date
    Completion Date
    ''Mark''
    Colonist
    Current Owner Name
    Former Owner Names
    Color - Body
    Silver-Grey Pearl
    Color - Stripe
    None
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    Other
    AOD
    Rear Gear Ratio
    3.31
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Heater
    • AC
    • Backup Light
    • Wipers
    • Custom dash
    Southeast US
    Electric power steering
    Rear camera
    Under car exhaust
    Electric parking brake
    Image Attachments
    FFR Number
    F5F1000626CP
    Delivery Date
    Completion Date
    ''Mark''
    conway witten
    Current Owner Name
    conway witten
    Former Owner Names
    Color - Body
    Ford Sonic Blue Pearl
    Color - Stripe
    Wimbeldon White
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    4.10
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    255
    Tire Size - Rear
    315
    Optional Equipment
    • Radio
    • Heater
    • AC
    • Wipers
    Southeast US
    Image Attachments
    Senior Member GThompson's Avatar
    Spencerport, NY
    FFR Number
    F5R1000338CP
    Delivery Date
    Completion Date
    ''Mark''
    GThompson
    Current Owner Name
    George Thompson
    Former Owner Names
    Color - Body
    Black (not yet painted, will be Guardsmen Blue)
    Color - Stripe
    N/A (not yet painted, will be Wimbledon White)
    Engine Displacement
    302
    Engine Induction
    Stack Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.27
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Pin Drive
    Wheel Size
    15''
    Tire Size - Front
    245
    Tire Size - Rear
    295
    Optional Equipment
    • Foot Box Vents
    • Backup Light
    • Wipers
    Northeast US
    Image Attachments
    FFR Number
    F5R1000649CP
    Delivery Date
    Completion Date
    ''Mark''
    WALLACE18
    Current Owner Name
    Tom Wallace
    Former Owner Names
    Color - Body
    Mettalic grey
    Color - Stripe
    Black
    Engine Displacement
    5.0 Windsor
    Engine Induction
    Injection
    Transmission
    T5
    Rear Gear Ratio
    3.27
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    255
    Tire Size - Rear
    315
    Optional Equipment
    • Power Brakes
    • Radio
    • iPOD/MP3 Player
    • Heater
    • AC
    Southeast US
    I built this coupe with the idea of what would one look like if Carroll ever built one just for the street. I deleted the scoops and added side 1/4 vent windows, radiator shroud from Russ Thompson. The engine has Trick Flow heads and Proinjection III. Car weighs 2260 and is very fast and stable. A/C works great and I tinted all the windows as well. I added heat shields and other stuff to keep heat in cockpit down. Huegenics did paint and final body work. This is my 4th FFR car and I hope to keep this one a while. I enjoy driving this car and it attracts lots of attention any where I go. Check out my build thread wallace18type 65.
    Image Attachments
    Dec 2012
    Prosper Texas
    FFR Number
    285
    Delivery Date
    Completion Date
    ''Mark''
    DcoupeMan
    Current Owner Name
    Former Owner Names
    Color - Body
    Coper
    Color - Stripe
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    Other
    3550 TKO
    Rear Gear Ratio
    3.73
    Differential Type
    Limited Slip
    Aburn
    3-Link
    Shocks
    Bilstein
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Optional Equipment
    • SAI Mod
    • Wipers
    Texas US
    Image Attachments
    Sacramento Area, California
    FFR Number
    F5R1000716CP
    Delivery Date
    Completion Date
    ''Mark''
    Ron J
    Current Owner Name
    Ron Jolly
    Former Owner Names
    Color - Body
    BLACK
    Color - Stripe
    TITANIUM GRAY
    Engine Displacement
    347
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.73
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Wipers
    NorCal US
    Image Attachments
    FFR Number
    F5R000417CP
    Delivery Date
    Completion Date
    ''Mark''
    Roger Dieter
    Current Owner Name
    Roger Dieter
    Former Owner Names
    Color - Body
    Championship White
    Color - Stripe
    Deep Blue Metallic
    Engine Displacement
    347
    Engine Induction
    Turbo
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    255
    Tire Size - Rear
    295
    Optional Equipment
    • Radio
    • iPOD/MP3 Player
    • Heater
    • AC
    • Trunk Battery Box
    • Wipers
    Northeast US
    Image Attachments
    FFR Number
    F5R1000716CP
    Delivery Date
    Completion Date
    ''Mark''
    Ron J
    Current Owner Name
    Former Owner Names
    Color - Body
    RED GEL COAT
    Color - Stripe
    Engine Displacement
    347
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.73
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Backup Light
    • Wipers
    NorCal US
    Image Attachments
    Apr 2015
    Southern California
    FFR Number
    There is NO number stamped on the frame.
    Delivery Date
    Completion Date
    ''Mark''
    1ShelbyGuy
    Current Owner Name
    John Saia
    Former Owner Names
    Judge Lester Gerard
    Andy Schaffer
    Car Was Complete
    Color - Body
    Guardsman Blue
    Color - Stripe
    Wimbledon White
    Engine Displacement
    Other
    Engine Induction
    Stack Carburation
    392 Ford Motorsports
    Transmission
    TKO 500
    Rear Gear Ratio
    3.31
    Differential Type
    Tru-Trac
    IRS
    Shocks
    ''Other'' Shocks
    Pin Drive
    Wheel Size
    15''
    Tire Size - Front
    235
    Tire Size - Rear
    295
    Optional Equipment
    Northeast US
    Image Attachments
    Jan 2013
    FFR Number
    721
    Delivery Date
    Completion Date
    ''Mark''
    Ricobrafan
    Current Owner Name
    Christopher Benson
    Former Owner Names
    Color - Body
    White
    Color - Stripe
    Bkack
    Engine Displacement
    Other
    Engine Induction
    Injection
    363
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Trunk Battery Box
    • Backup Light
    • Custom Mirrors
    • Wipers
    Northeast US
    Image Attachments
    Member mcmustang's Avatar
    Boise, ID
    FFR Type 65 Coupe number 337
    Factory Five Type 65 Coupe Registry Entry
    FFR Number
    F5R1000337CP
    Delivery Date
    August 21, 2007
    Completion Date
    September 30, 2019
    ''Mark''
    mcmustang
    Current Owner Name
    Michael and Karen Clarke
    Former Owner Names
    none
    Color - Body
    Lexus Spectra Blue 8M6
    Color - Stripe
    no stripes
    Engine Displacement
    5.0 Windsor
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    2.73
    Differential Type
    Traction Lok
    4-Link
    Shocks
    Bilstein
    Standard
    Wheel Size
    17''
    Tire Size - Front
    235
    Tire Size - Rear
    235
    Optional Equipment
    • Power Steering
    • Power Brakes
    • SAI Mod
    • Heater
    • AC
    • Trunk Battery Box
    • Wipers
    Northwest US
    Frame painted custom light blue.
    Roundels and numbers are reflective.
    Backup camera and CHMSL integrated into rear spoiler.
    Grenade for shifter knob.
    Images Links:
    171177591.jpg 171191135.FtvPj3Lz.jpg 171191134.Dp95Z5KJ.FB_IMG_1601952384154.jpg 171191136.QOYwCfGX.FB_IMG_1601952943324.jpg 171191128.jpg 171191213.jpg 171191137.jpg 169854197.jpg 171191214.jpg
    FFR Number
    F5R10007123CP
    Delivery Date
    Completion Date
    ''Mark''
    Hobbie 57
    Current Owner Name
    Rick Hobson
    Former Owner Names
    N/A
    Color - Body
    Red gelcoat
    Color - Stripe
    N/A
    Engine Displacement
    347
    Engine Induction
    Carburation
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Heater
    • AC
    • Trunk Battery Box
    • Wipers
    Northern Central US
    Image Attachments
    Senior Member Hoschton Hotrod Haus's Avatar
    Sep 2019
    Hoschton, GA
    FFR Number
    F5R1000181DC
    Delivery Date
    Completion Date
    ''Mark''
    Current Owner Name
    John Mark Gray
    Former Owner Names
    Color - Body
    Red
    Color - Stripe
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • AC
    • Wipers
    Southeast US
    Image Attachments
    FFR Number
    0000069
    Delivery Date
    Completion Date
    ''Mark''
    NERGLHAD
    Current Owner Name
    Doug Dahlgren
    Former Owner Names
    Color - Body
    Blue
    Color - Stripe
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    235
    Tire Size - Rear
    245
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Trunk Box
    • Backup Light
    • Custom Mirrors
    • Wipers
    • Custom dash
    Northern Central US
    Image Attachments
    Senior Member dstelter's Avatar
    Jan 2019
    Paige TX
    FFR Number
    169 gen 3
    Delivery Date
    Completion Date
    ''Mark''
    dstelter
    Current Owner Name
    Douglas Stelter
    Former Owner Names
    Color - Body
    Light Blue
    Color - Stripe
    White
    Engine Displacement
    408
    Engine Induction
    Carburation
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    15''
    Tire Size - Front
    255
    Tire Size - Rear
    305
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Backup Light
    • Wipers
    Texas US
    Image Attachments
    FFR Number
    FFR4438CP
    Delivery Date
    Completion Date
    ''Mark''
    calif. cobra guy
    Current Owner Name
    Boyd henderson
    Former Owner Names
    Partially Built (Not the Original Purchaser)
    Color - Body
    blue
    Color - Stripe
    white
    Engine Displacement
    302
    Engine Induction
    Carburation
    Transmission
    T5
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    16''
    Tire Size - Front
    215
    Tire Size - Rear
    235
    Optional Equipment
    • Radio
    • AC
    NorCal US
    Image Attachments
    FFR Number
    F5R1000716CP
    Delivery Date
    Completion Date
    ''Mark''
    RonJ
    Current Owner Name
    Ron Jolly
    Former Owner Names
    Color - Body
    Boulevard Black
    Color - Stripe
    Track Red
    Engine Displacement
    347
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Tru-Trac
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Radio
    • iPOD/MP3 Player
    • Heater
    • AC
    • Backup Light
    • Custom Mirrors
    • Wipers
    • Custom dash
    NorCal US
    Image Attachments
    Jan 2021
    FFR Number
    dont know yet
    Delivery Date
    Completion Date
    ''Mark''
    only1morereaccaripromiss
    Current Owner Name
    Shanon Galusha
    Former Owner Names
    Color - Body
    custom dark grey
    Color - Stripe
    matte black
    Engine Displacement
    427
    Engine Induction
    Injection
    Transmission
    Other
    TKX
    Rear Gear Ratio
    3.55
    Differential Type
    Torson
    IRS
    Shocks
    Other
    ''Other'' Shocks
    viking
    Standard
    Wheel Size
    18''
    Tire Size - Front
    275
    Tire Size - Rear
    Optional Equipment
    • Power Steering
    • Heater
    • Foot Box Vents
    • Front Splitter
    • Custom Mirrors
    • Wipers
    • Wind Wings
    Northwest US
    Image Attachments
    Dec 2019
    FFR Number
    F5R000273DCB
    Delivery Date
    Completion Date
    ''Mark''
    Walsh3328
    Current Owner Name
    Tech Autos
    Former Owner Names
    Color - Body
    Lightning blue
    Color - Stripe
    Oxford white
    Engine Displacement
    306
    Engine Induction
    Injection
    Transmission
    TKO 600
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Heater
    • Wipers
    Western Europe
    Image Attachments
    FFR Number
    208
    Delivery Date
    Completion Date
    ''Mark''
    BBOMAR
    Current Owner Name
    Ben Bomar
    Former Owner Names
    Bill Justice
    Color - Body
    Red Gel
    Color - Stripe
    Engine Displacement
    302
    Engine Induction
    Injection
    Transmission
    Other
    TKX
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Power Brakes
    • Radio
    • Custom Mirrors
    • Glove Box
    • Wipers
    • Custom dash
    Southeast US
    Image Attachments
    Jan 2018
    FFR Number
    F5R1000331DC
    Delivery Date
    Completion Date
    ''Mark''
    Sell1
    Current Owner Name
    Pete Sell
    Former Owner Names
    Color - Body
    RED
    Color - Stripe
    White
    Engine Displacement
    5.0 Coyote
    Engine Induction
    Injection
    Transmission
    Other
    GETRAG MT82 6 SPEED MANUAL TRANSMISSION
    Rear Gear Ratio
    3.55
    Differential Type
    Torson
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    315
    Optional Equipment
    • Power Steering
    • Heater
    • AC
    • Trunk Battery Box
    • Custom dash
    Northern Central US
    Image Attachments
    Dec 2021
    David,
    We're looking to start a GEN3 coupe build later this year. while doing research now. I have two brothers who each built roadsters. Looking for an owner to talk in person with near Dayton, OH or within 200 miles or so. Do you know anyone?
    Todd & Brian
    Mar 2015
    FFR Number
    F5R1000352DC
    Delivery Date
    Completion Date
    ''Mark''
    25mike87
    Current Owner Name
    Michael D Arentz
    Former Owner Names
    Color - Body
    Satin Grey
    Color - Stripe
    Black
    Engine Displacement
    Other
    Engine Induction
    Injection
    376
    Transmission
    T56
    Rear Gear Ratio
    3.55
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    275
    Tire Size - Rear
    315
    Optional Equipment
    Northeast US
    Image Attachments
    May 2016
    FFR Number
    FFR1000192CP
    Delivery Date
    Completion Date
    ''Mark''
    racerfrank
    Current Owner Name
    Frank Swiader
    Former Owner Names
    Mark Reid
    Craig Dean
    Color - Body
    White
    Color - Stripe
    blue
    Engine Displacement
    Other
    Engine Induction
    Carburation
    Transmission
    Other
    will be tr 3550
    Rear Gear Ratio
    Other
    not known at this time
    Differential Type
    Open
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    235
    Tire Size - Rear
    305
    Optional Equipment
    Northeast US
    Image Attachments
