Thanks- Chad
Brandon, Call Jim Schenck @ FFR. I believe the Factory R is running Wilwoods...
Brandon, the wheel bearings are going to survive much, much longer since they are only carrying half the weight...
Good stuff. I put the advice on this forum over all others. I will just do new stock bearings and call it a day. Thanks for the guidance
I extended the arms to their fullest and they get around 1 1/4" inch more reach. They are slightly heavier than the stock arms. In the closeup you can see the silver where I had to machine off about 1/8" inch from the black spacers. In my opinion the quality seems fine. Hope this helps
I have the same transverse arms but did not buy the trailing arms. I also had to machine the bushings for th transverse arms, I cut equal amts from each side. IIRC they were approx. .100 too wide
Dan
LIC Motorsports machines sti front knuckles to fit WRX applications. you can get them with 5x100 hubs.
I would see how fast your first set of bearings wears out before you drop the cash to swap them out.
http://www.licmotorsports.com/produc...i_lic-03079012
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
In this setup the wrx bearings will last a lifetime.
Tony Nadalin
6 piston brakes will be overkill- You can save the cash for something else. I have 2 piston fronts on a heavier race car that is 40+ years old..... Never had a braking issue with correct fluid and pads.
Thanks- Chad
Either way the rear knuckle calipers need to be 4.5" between the holes. I wasn't able to find a solution to make the rear Wilwood caliper bracket work with a knuckle that will take a 5 x 114 (3.75" between holes) so I just opted to press new bearings in the rear. The 4 or 6 piston will still run into an issue if you get the rear STI knuckles to support 5 x 114.
The solution I ended up going with is purchase new front knuckles with larger pre-pressed 5 x 100. I didn't want to locate & purchase 4 new axles to fit the 114's so this works well for me. Until a few days ago I wasn't aware they changed the front wheel bearing size after a certain year. It is my understanding these are more robust than the 2002 bearings I had from my donor but still 5 x 100. I will get more details unless someone else can elaborate further on this.
Speaking of that POS...I think i need to take a moment to vent.
For those of you building an R...I feel using a donor isn't the best way to go. I see many of the R builds are not going that route and you guys made a smart decision IMO. I think if you dig hard enough to find an ideal fit for the donor then perhaps it might be worth it if you wish to keep things stock. Not realistic especially for track use.
What I have used at this point from my donor:
- A peddle box that needed some bending to get to fit due to donor accident
- Steering Rack (had to replace 1 tie rod end)
- Axle pieces
- A few nuts and bolts
THATS IT!!
Replacement List:
- I tried to bleed my clutch last night but it shot a drop or 2 per compression. Trashed.
- The master cylinder looked pretty tattered. The damage from the crash jacked up the bracket. Turns out you can't just order that bracket without the booster (that i could find). So i just ordered replacement brake & clutch cylinders
- Tire & wheels are obvious replacements as are the seat(s)
- Donor didn't come with a motor so I found one with $3k which supposedly had 45k mi. That's was for the motor, trans and they threw in a radiator for free.
- My rear knuckles didn't work for the Wilwood setup and front i replaced for something with a slightly better bearings.
- I'm assuming the Boyd tank that's coming my way wont need the donors fuel tank pieces
- Some of my rear traverse/trailing arms were either bent or stripped/stuck together. Not to mention no ability to adjust them.
- Crash damaged to the left front LCA, so went with 06 aluminum LCA's
- Steering column i suppose I can use, but there was no key! I decided to purchase a second column. One will be stripped and painted and one will be street. Not sure how i will deal with the key situation being 1 column wont use it anyways
- Wire harnes...I guess that's up to your patients level. I can't see myself spending weeks learning and dieting wires. I would blow a head gasket. I did still need 7 ends of the donor harness to splice into the TEC-S VCP sells so i suppose that might count for something.
All in all I also chose poorly on my donor. Most of you found a much more usable WRX to dismantle.
The time and energy spent stripping the donor probably wasn't a financially sound move...but it did help pass the time waiting for my kit and hacking away at it was a stress reliever
Does anyone have a clear shot of how this piece goes in? I can't seem to find one.
The rear body mount brace didn't line up, it was about 1/8" off. The only way I could secure it was by using a vice
I did a test fit and will be shaving off at least 1/4" of the linkage today so i can find 2nd, 4th and reverse.
This is 3rd
Here is neutral
What is the purpose of the aluminum in the scoop? Can this be omitted?
Just for fun... a taste of months coming
Just for fun. I treated myself and the family a preview of whats to come
that piece of aluminum is part of the IC ducting
Dan
I scraped it and vented it, I am in not using the FFR supplied ducting, my plans are different. I also plan on using the r winshield down the road.
I'm not a fan of that ducting system either, please keep posting alternatives
Dan
I'm pretty sure that's not the IC aluminum, from what I can tell its a piece of front cockpit trim that doesn't fit the R... there should be another for the other side. You will need to make your own to fill the holes. Unless FFR sent me two sets, I have my IC aluminum wrapped up still. So I could be wrong.
After grinding the shift bracket as far as I was willing it was still binding against the rear fiberglass panel.
I ended drilling out the center of the shift bracket so I could slide it a bit deeper then redrilled the pin hole. It worked great, I have plenty of room now.
That's what I did, great minds think alike .
FFR did send you two sets of IC ducting... the second came in that "upgrade box" that they sent to all of us!I wrote old on one set and revised on the other...
Dan
Upgrade box? Haven't received but good to know. No B.O. shipments received either but i'm being patient as it hasn't even been a month yet since delivery.
Yea I scraped them all, aluminum is worth some money ya know lol. I honestly can't see how there ducting works that great. I am going to use the quarter vent holes I cut out to go to a vent in front of the rear well that deflects the air towards the cooler. Maybe it works, maybe I will try something else, but I will be checking for cooler temp and airflow readings before, after, different idea etc.
Dan
I will start bugging FFR for B.O. items once I run out of things to do.
My shift linkage is finally done and I'm really happy with the location. I installed the shifter in the stock location but it didn't feel right. I liked what longislandwrx did and positioned the shifter under the rails. It feels much better lower and more forward.
I also installed the IC aluminum, gas pedal and removed unneeded aluminum from the steering column and painted it.
Last edited by Brando; 02-11-2014 at 02:09 AM. Reason: Because I don't want people to know i misspelled the word pedal - hah
Thanks for showing me the way.
I have 2 steering columns. One stripped the other stock. I do intend to get this registered and drive on the street occasionally. It too sweet a car not to
i'm pretty sure here's that piece, as seen on Eriks car.
That looks like one of the pieces that close off the front fenderwell area of the car. There should be a left and a right one and they fasten to the frame just inside the front suspension.
L.I.wrx have you found a spot for panel pair 80129 on your R?
Drdracing i think you might be referring to 80174, i was looking for 80129. I have received a few pairs of panels that belong exclusively for the S. I think panel 35 & 36 are a few of those
Tonight I tried my luck in applying vinyl 4d wrap on my interior dash. FAIL. That turned out harder than it looks i will leave it to the pros. In hindsight i should have snapped a picture it was good for a laugh
On a better note I received my clutch & brake master cylinders today. I know might seem trivial but after upgrading the clutch, mating the trans,installing motor, bleeding lines then finally pressing on the clutch pedal and having the pressure plate release felt like a milestone achieved. Easily pleased I suppose but I am going to bed satisfied
I'm ready for tires and wheels. I took the plunge today and went with the following
Wheels: (from VCP)
Enkei Kojin
17x8 + 45 Front
18x8.5 + 45 Rear
Tires: (tirerack)
Hoosiers R6
225/40-17 Front heat cycled
255/35-18 Rear heat cycled
Brando, I understand the thrill of the small victories like your clutch pedal. It's all the little victories that make the build so much fun. Last night I identified and tagged a bunch of the wiring harness ends, thanks to Mechie3's work, and left the garage feeling successful. It's all about hundreds of little victories.
Nolan
Brando... no it wont fit, just saving it for spare aluminum. the bar it attaches to is absent on the R. This is where it goes:
Finally the mystery is solved. Well played thanks.
I wanted to ask you another question. Are you planning to cut your center dash to fit the shifters custom location or going with a aluminum custom piece like Aloha818 did?
I think I'm going to end up with a combination of both. I'm going to start by having one of the "legs" of the tunnel sheared off, and then cut a hole on top for the shifter. Then I can rivet the top and left side as one but have the right hand rivnuted so it can be unscrewed for access. I have to see how the fiberglass piece fits without the shifter piece. I may need to make an adapter up front.
Since I have my transfer case disassembled and therefore access to the shifter, I am thinking of re-drilling the hole in the rod and cutting off atleast 1/2 inch of shaft.
