Thread: What are these?
    Groton MA
    What are these?
    Computer issues, this is my third attempt at this post.
    What are these two connectors and the two boxes?
    The two connectorsIMG_0471[1].JPGIMG_0473[1].JPG are close to each other and also connect to similar ones.
    The box pictured is on the rear harness and there is another box back there that says Caution Hot!
    What are these and can they be deleted?
    Pete
    pete, I can't help with your question but as an aside, make sure your pics are no more than 1900x1900 if you want them to show inline...
    Frankfort, IL
    I googled the part number for the 2nd picture - it's the fuel pump controller.
    Nov 2012
    Medina, OH
    I don't have time to look it up right now, but quick guessing?
    The connectors look like the ones going to the fuel pump relay and another relay next to it.
    The box is the fuel controller.
    The caution hot box sounds like the rear defrost module. I deleted that but kept the supply wire as a possible seat heat power supply. I'll check back later tonight to confirm if no one beats me to it.
    Rich
    Nov 2012
    Medina, OH
    What year is your donor? I'm drawing a blank on those connectors. The colors of the wires don't match any of the ideas I've had. I'm referencing an 07, my donor year. They look small at second glance to be those relays. I thought maybe the cooling fans, but wire colors are wrong.
    Rich
    Groton MA
    The doner is a 04 WRX.
    I thought it may be air bag or seat belt related but the two were together and there is another just like it.
    Keeping the fuel controller and wrapping those wires today.
    I moved the harness from the table to the car and now have the "Rats Nest" on the passengers floor.
    Trying to identify, wire wrap and place what is there in its location but there is so much,,,,,,,
    Nov 2012
    Medina, OH
    I'm going with seat heat switch connectors. I didn't have those. R42&R43
    Rich
