When we say to our customers "if there is anything you need, please ask," we mean it.
iWire Subaru Wiring Services
Over 100 Custom 818 Wiring Harnesses Built
http://www.iwireservices.com/factory...18-wiring-kits
[email protected]
http://www.enginewiring.com/catalog.htm#Featured
Well look at that wiring
Thanks- Chad
I'm not entirely sure why you need the vss simulator. Is this something I'll need to look into with my iwire harness?
Btw, post more videos Chad. The sound in your videos makes me want to drop whatever I was planning on doing and get back in the garage.
Hahah! Looks great Chad! :P That's weird part of my job. You know I'm doing it well when no one notices it. haha
You will not need that. Chad is running an 05 LGT trans that does not have a VSS (05 LGT gets it from the ABS). Yours will be totally normal and use a stock VSS.
[email protected]
Chad seems to always want to be different
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
Thanks- Chad
Tony Nadalin
which model of those fuse/relay boxes do you use for these harnesses? I really like them, on the website I was looking at they have a 15303-2 -4 -5 and -6. was wondering which ones you used?
[email protected]
Just an update to the thread.
I really need to rename this harness. Working on the first true S model and have sorted the factory steering column issues. So, although it is designed for the "less is more crowd" most S owners would be very happy with all features available.
[email protected]
One more update.
We're now offering the choice for circuit breaker or fuse for the main power wire and no more solder joints to shorten the main engine plugs as I have found a source for the terminals (note: these are NOT for sale, sorry guys have to keep somethings to myself).
These are panel/dash mount style but will also be available in a surface mount style depending on what people want.
[email protected]
Very nice. If I ever pop a main fuse, I'll grab one of those. I don't think I ever have popped the main one, but it would suck if you were at the track!
Thanks- Chad
It's so unlikley. Pretty much the only time I've ever seen the main fuse blow is if you arc the alternator when taking the terminal off with the battery still connected. I put an extra main fuse in the box so you should have one you can carry down so at least you can keep going if something were to happen.
Do you want a circuit breaker? It's not really an improvement so to speak, just adds options because some are partial to one over the other.
[email protected]
First S harness completed and out the door.
https://www.facebook.com/media/set/?...1¬if_t=like
[email protected]
Look close to the R harness, well at least my R harness since Chad had to be different
Tony Nadalin
Very close to the R (except for Chad's because he's "special"). Big difference is no switch panel and use of factory column switches. He also has leads to hook up an AC system. It's more a function of letting people know that this kit can fit the bill for most builds, S or R.
[email protected]
What's the price on s model and what's needed to be sent in? Or can we sell off the factory harness to offset the cost? Thx
Man I wish these wouldn't break my budget bank. It would be amazing in my kit.
Same price as R. It might be a little more depending on how many add-ons you want. I need the factory Subaru harness because I use it as the base to build this one. Besides the factory harness, ECU, and fuel pump controller I just need the lighting plugs and the fuel tank plugs that FF provides.
I wish I could bring down the cost, but the time in labor and cost of materials just doesn't make that possible at this point.
[email protected]
[email protected]
Tony Nadalin
[email protected]
Good chunk of the way done on Six Star Car's builld.
https://www.facebook.com/media/set/?...1784988&type=1
http://thefactoryfiveforum.com/showt...d-Build-Thread
[email protected]
How did I miss these 2 latest updates?
Nice looking S harness. Can't wait to get ahold of it!
[email protected]
Six Star Cars is done. Ready to start your Jason. Thanks for your patience.
[email protected]
Need to step up that production line ! Its so simple you just connect the red wire to white wire
Tony Nadalin
Awesome, looking forward to it.
Hello, I'm really interested in this wiring kit but I have an 05 STI donor car and it has become my full track car. Therefore, my stock wiring harness is pretty much cut up for weight saving purpose. I have a few questions. This is for the S model as I like to be street use but more of a hybrid like an RS a little bit more on the track side.
1). I will be using my 05 STI as donor and I would like to see if the harness will work or I may decide to use the 04 STI ECU to eliminate the immobilizer or can I just use a 06 WRX ECU which is a 2.5L? Whichever is easiest.
2). Of course I wouldn't be needing the DCCD function and I will be using the 05 STI dash cluster instead of a WRX. Can it be wired up using the STI cluster?
3). Like I said, my stock 05 STI wiring hardness is chopped up. So do I need to sent in my stock harness or how's that going to work out? I really like to avoid to spend the time to take the stock harness out if not needed.
If I can avoid using the stock harness that would be perfect.
Thank you.
1. Yes, we can do that no problem. However, I would suggest that you leave the 05 ECU in there. It's actually a better ECU to tune. The problem with the 04 it's basically designed as a 2.0 WRX ECU and they slapped the drive by wire and AVCS as it was a bit of a band-aid for Subaru to get the first USDM STi out. The 05 ECU is the first actually built for USDM STi platform.
2. STi cluster, and any cluster someone might desire is not a problem. The plugs are the same as USDM WRX, it just has extra pins for the extra features.
3. What exactly is cut? Ideally I would need the ECU to engine section uncut as we use some of the stock harness as a base. Beyond that, it doesn't really matter as I can use just the leftover pieces or grab them off a scrap harness from here. Shoot me some pictures to iwiresales at gmail.com
Brian
[email protected]
[email protected]
First of 4 in 4 weeks done. So far on schedule.
https://www.facebook.com/11578616178...type=1&theater
[email protected]
2 for 2.
Just a heads up to anyone still looking for an engine. Any Impreza turbo/non turbo engine from 93-07 can be wired up with the factory ECU and will bolt right in to the 818. I generally recommend 02 and up because it opens up all of the modern tuning options, but it's not requirement.
https://www.facebook.com/media/set/?...=3&uploaded=12
[email protected]
Plenty of creature comforts on this S model!
[email protected]
