0
0
Originally Posted by
Hindsight
Ditto on all that. You will want both air and manual (manual for the tight spots, air for everything else). Air does a nicer job on the rivets too.
Buy a package of 10x 1/8" drill bits; they should be short and of high speed steel. Dip the tip of the bit into some oil before each hole. You'll need a regular drill, and an angle drill or angle drill adapter for some tight spots.
Went to harbor freight and got a manual rivet gun cause that is all they had. Couldn't find air. Or maybe i was blind. Either way all the air is in my other shop I also got a little portable blower heater . I get cold easy. I need to go get the 1/8" and 3/16" drill bits of high quality. How prevalent is it that I would get the angle drill?
