OK time for Brake lines.
I wanted to set up the proportional valve out of the way, so I picked a spot between the brake and Clutch master cylinders.
My goal is to keep the battery and open area in the front as uncluttered as possible as a possible mod later to add fuel tank in the front like Xusia and a couple others.
Or..... its an area to put some storage.
In any case, here's how it ended up.
Then routing down through the lower access area - you can also see the clutch line is not terminated yet. I am going to terminate and finish with a flex line from there.
and routing down the side - and split to two sides. I ran the line under the motor along the frame behind the engine mount supports to the other side.
and to the back flex connection
