Another Seattle 818R build here. I posted a couple threads related to issues I was having, but figured it is time to create a build thread. I have learned a lot from others' threads. Hopefully my thread returns the favor.
I ordered the frame unpainted since I figured I would need to make a few modifications. Boy was I right. I have already done a lot of cutting, welding, and grinding.
My kit options are:
- CF Race Splitter
- CF Rocker Panels
- CF Rear Diffuser
- 6-Speed
My donor is a 2004 STI that I had tracked for over 10 years (original owner). It was a bit bored with it and needed to spend a little on some maintenance. So I talked myself into doing the 818R instead . I knew going into this that the 6-speed will present some challenges. My old STI also had upgraded knuckles for 5x114, too. Basically 2005-2007 knuckles. This will require some modifications, too.
The initial plan was to get started with mounting the motor and trans in the chassis and modifying the 6-speed. Unfortunately, I ran into issues with the 6-speed conversion. Moved on to the interior modifications.
