Results 1 to 31 of 31
Thread: Just how many of the completed 818s out there will be able to be licensed legally
    Jan 2012
    95% completed my 818S chassis #55. Problem is State of Wisconsin will not register it since not replica of a car older than 20 years.
    My question is how many people have been able to register the vehicle in their states. I believe Alabama is one state. I think there are going to be many, many, many builders/ owners who will have completed a non-registerable car. A rather expensive garage decoration to say the least. So again, what states have allowed 818 licensing/registration, inspection?
    A quick look says in WI, you need to apply as a custom built vehicle, not a replica or hotrod.
    Most states should allow for registration with enough legwork.
    -Andrew
    Fresno, CA
    There are several registered in California, Nevada, Alabama, Texas and Arizona that I know of. Hopefully many people around the US will post here to help fill your half empty glass.
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Quote Originally Posted by DennisL View Post
    I would start here:http://www.bipac.net/semaga/TagTitle..._16-Apr-14.pdf. SEMA has done a great job of gathering most, if not all, the information needed for each State. Then, log onto WI's DMV site and research custom vehicles, home built, special construction etc.
    Good luck,
    Ray
    Houston
    In Texas, the regs. say a "Replica" has to "resemble"....an older vehicle.
    I used that to get my 818S registered as a "replica" with custom vehicle plates that exempt me from any future inspections (safety or emissions). Check my posts.
    fred
    Norton, MA USA earth
    Hope to be going through this in MA very shortly. Will let you know what happens.
    Exeter R.I
    RIimage.jpg, was pretty easy to get done
    Very easy IMO in Florida.
    IMO one should do his homework before he orders a kit. That way there are no surprises. It is easy to get caught up wanting to build a cool car, but like anything you have to do your homework first. JMO.
    USA
    Michigan is a piece of cake. It's called an assembled vehicle here. I've made golf carts, side by sides, and dirt bikes street legal. I think Arizona is the most lenient with this sort of stuff.
    http://www.michigan.gov/sos/0,4670,7...5476--,00.html
    Near Denver Colorado
    No problem in Colorado. MCO, FFR invoice, receits for wheels, tires, drive train and a safety inpection by the state patrol. Finally bunch of paper work for some very fussy clerks! The process is a couple of months long.
    Larry
    Sep 2014
    Dallas, TX
    Quote Originally Posted by freds View Post
    fred
    What did you say it was a replica of?
    818S Chassis #288 2.5L 323hp
    joshuajach.com
    Stillwater, NY
    Sounds like you need to do some more research (that you should have done before getting the kit). You have to think like a bearucrat. Yea, it's not a replica, it's Homemade according to Wisconsin (less than 10 minutes of googling):
    http://www.dot.state.wi.us/statepatr...n/homemade.htm
    http://docs.legis.wisconsin.gov/code...rans/305/I/065
    http://search.wi.gov/cs.html?url=htt...scon&n=1&la=en
    http://www.dot.state.wi.us/drivers/v...l/hobbyist.htm
    Wisconsin
    Good morning Dennis,
    In Wisconsin, try the "Hobbyist" License Plate designation as that one is relatively flexible. It will still have to be inspected and given a State VIN number, but should otherwise pass muster. Basically it has to have a hand brake and possibly a windshield wiper. The only restriction on Hobbyist plates is that you not drive the car in January - and unless you own snow tires, that shouldn't be a problem!
    http://www.dot.wisconsin.gov/drivers...l/hobbyist.htm
    Look at the "Home Made Motorized Vehicles" designation. What's extra nice is that it's a one-time fee. Once registered and licensed, it is good for as long as you own it with no annual renewals. Plates are transferable to another vehicle, too so you can keep your Plate #. One added benefit is that it is close to the Packer's color scheme (green and gold).
    I've registered each of my FFR cars as Hobbyist and have had no problem. Each time I registered my cars (one a full competition Challenge series car and the other the '33 street rod) the "inspection" was to verify that the VIN tag had been properly fastened in the correct place. Both officers upon inspection of the plate said things like "Nice Paint!" or "How much Horsepower?" No challenges on lack of hand brake on the Challenge Series car, no DOT windshield, no wipers, etc. On the '33 no challenges on the lack of wipers or essentially anything.
    I also registered two '50s era Jaguars in full race trim under the Hobbyist designation and got plates in the mail without any inspection since they already had VIN plates. (again no DOT windscreens, wipers or hand brakes and not even DOT tires in one case.) I've never been stopped in any of my Hobbyist cars, even when out-of-state driving these cars.
    I think you'll be fine if you designate the "Hobbyist" plate registration.
    Best regards,
    Tom
    Member tebriel's Avatar
    WI
    That's great to hear Tom. I was slightly concerned about someday having to get a VIN in WI. You haven't built a registered an 818 yet though here?
    Wisconsin
    Hi T, Re: You haven't built or registered an 818 yet though here?
    Nope, not yet but it's a future possibility. First I have to pass the idea by the Registration Wife. She already thinks I have too many pistons available to me!
    Best regards, Tom
    Mar 2014
    Silver Spring MD
    I am now registered in Maryland. I needed a VIN inspection by the State Police and a safety inspection by a private garage. I will need to report to the emissions station in the future. My car is likely to pass since but kit cars are exempt.
    Frankfort, IL
    You can add your neighbors to the south to the list - Illinois allows registration. Fairly easy process once you get over the waiting while they process paperwork (I'd say it was around 5-6 weeks from my initial phone call until license plates were at my door).
    How to register in IL?!?
    Quote Originally Posted by billjr212 View Post
    Which process did you go through to register the 818 in Illinois? I'm struggling to get a Exocet registered under the specially constructed vehicle process as they are demanding NHTSA certification.
    Is this the route you went, or how did you register in IL?
    Frankfort, IL
    Special Constructed Vehicle process is what I used, correct. Have you gotten in touch with the specific guy that handles them? When I registered mine, it was a single person that handled all of them, but I think I heard he left. Anybody else you talked to had no clue.
    You should have received a packet of information from the Secretary of State including Form VSD 843. Once you get in touch with the right person, it is a fairly simple process, just involves quite a few steps and a bit of back and forth (unless they changed something yet again). Ultimately you just need to prove out where each major component comes from, then get an inspection from the secretary of state police (they come to your house).
    https://www.cyberdriveillinois.com/p...ons/vsd843.pdf
    I spoke with Alan who seemed to know the process very well (been in the position a few years at least) but it was his supervisor Debbie who apparently does the "research" to determine if a vehicle meets standards or not. Did you have any issues with "NHTSA certification" or just submitted the MCO for the 818 frame and donor info? I assume the frame had NO VIN on it, just a serial number from the MCO correct?
    Frankfort, IL
    Quote Originally Posted by jmills View Post
    Exactly. No mention of nhtsa certification by them. They may be trying to react to the new federal law for small volume manufacturers, but it shouldn't apply to kits.
    Mechie3's Avatar
    Indiana gave me a VIN and plates and let me register it. It still hasn't moved under its own power. Haha! (I mean...it's not funny I haven't finished yet, but it is funny they let me register it).
    Zero Decibel Motorsports
    Senior Member AZPete's Avatar
    Another One Hits the Pavement! I just got a VIN, title and plates from the Arizona DMV this morning! It took 5 boring hours to get the level 2 inspection, paperwork, and all. They copied all receipts in my 3-inch file of receipts - even the little receipts for nuts and bolts from Ace Hardware and Lowe's! But, my 818 is classified as a "2013 SPECO" (special construction) so I don't have to get emissions tests. (whew).
    This thread was started by DennisL when he was frustrated by licensing nearly a year ago. Hey, Dennis, did you ever get plates?
    Saint Charles IL
    Quote Originally Posted by Ray View Post
    Good luck,
    Ray
    Ray,
    Your post has been extremely helpful! I am about to go through Illinois registration which doesn't seem bad, but that link surely helped... so, here it is again by state: http://www.bipac.net/page.asp?conten...olbox&g=SEMAGA
    Also helpful: http://www.bipac.net/page.asp?conten..._bill&g=SEMAGA
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I was able to register my 818 in Georgia. I did a write-up on it here: http://thefactoryfiveforum.com/showt...car-in-Georgia
    I completed registration & titling of my build in Maryland as a two-stage vehicle.
    Saint Charles IL
    Quote Originally Posted by mikeb75 View Post
    Two-stage vehicle? That's a new term to me... from a quick googlin' just reconstructed, correct?
    Two stage means Booster Rockets?
    Maryland description of two stage vehicle means there are two manufacturers where reconstructed is a vehicle created by the unique alteration of a standard vehicle. Semantics, but I think a different body on an existing frame would be a reconstruction; but since there is a frame provided by FFR & engine/drive components from Subaru it meets the definition of two-stage. At least that is how I was registered (I think, it was actually never written on paperwork I saw).
    Maryland, no space industry here - but we like "putting on airs".
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Have you read through this: http://www.bipac.net/semaga/TagTitle..._16-Apr-14.pdf ?
    Ray
    Freeport, ME
    soon to be 3 registered in Maine...
    Like others have indicated, read the rules, go through the steps, some places are easier than others
    Dan
