Results 1 to 11 of 11
Thread: Yellow tape on subie harness
    South Jordan, Utah
    All the wire looms wrapped in Yellow tape are Air Bag circuits Correct?
    Feb 2014
    Ramona, CA
    Yes.
    And also seat belt stuff.
    Feb 2014
    Asheville, NC
    The one exception in my 2002 was teh hazard light switch had yellow tape around it, I believe.
    I don't think it transposed to 2003, I did not have yellow tape on the hazards.
    South Jordan, Utah
    Second Question about these circuits, Can they all be removed without effecting the operation of the computer?
    Feb 2014
    Asheville, NC
    Airbag, yes. Roy what year is your harness? There's a really good write up on 06's and I have an okay one started on the 02's that I will someday make pretty.
    Leesburg, VA
    Roy, take a look at Larry's guide to dieting the wire harness. I followed it and cut away at least 20 lbs of unneeded wire/connectors/wrapping:
    http://thefactoryfiveforum.com/showt...l=1#post152338
    It was also extremely helpful on figuring out where to start.
    South Jordan, Utah
    Thanks for the link. That is a lot of good info. Thanks Larry for the write-up.
    This Subie wiring makes the mustang donors for the roadsters look like simple circuits.
    Oh my donor is a 2007 WRX
    I have it stripped out up to the dash. I started in the back and I am working forward.
    Feb 2014
    Asheville, NC
    Oh man, the "old" Subarus are so much easier. The wiring for my 2012 is a nightmare...
    http://thefactoryfiveforum.com/showt...h-Auto-AC-HVAC
    Check that thread out!
    Feb 2014
    Asheville, NC
    Also, here's the wiring diagrams.
    http://ken-gilbert.com/impreza-manuals
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by Roy View Post
    You're welcome. Someday I should finish it. Maybe if I have a bad weather day at the beach next week I'll work on it.
    Larry
