6t8dart
I got off work a little early today, so I decided to build a body buck. I have a buddy coming over Saturday, he doesn't know it yet, but he is being "volunteered" to lift the body off.
I think I screwed this up, I ran the side supports at 63" apart, however, I forgot that the body pinches in at the bottom and is only about 54" wide. I have to do a little more measuring and see if the sides will clear, if not, I need to tear it apart and move them inboard each about 6 "
6t8dart
Ok, we got the body on the buck yesterday, the fit was just horrible! But then, I wondered, what if we turn it 180 degrees? Wow, fit much better! Lol! It still could be better in the back, I may make a couple pieces to screw to the existing boards and adjust the fit a bit. I think F5 needs to redraw their patterns for the MKIVs.
