Right on guys. It's never as bad as it seems.
What I thought would be an intense modifcation turned around quite quickly.
By adding a second u-joint on the steering cloumn, the maximum
angle was cut from about 60 degrees down to 20 degrees (approx.).
![](http://www.ffcars.com/forums/attachments/factory-five-gtm-forum/210753d1442524095-gtm-gen1-105-fires-up-20150917_124307.jpg)
You can see in this image that the angle is severe:
The end result:
Had the previous owner not welded a portion of the shaft, I may have
completed the task in half the time.
The shift action should be better as the rear cable bracket was adjusted
about 1/4" to the back allowing the transaxle lever to lock fully.
Lots of testing to come this weekend, and possibly a car show Sunday.
Hopefully the primer, and pin holes shine bright with the morning sun.
