Working on my rear bumper today.
I like the clearance gage for the transmission! TPS(Three Paint Stick) is more than adequate!!
As you can see a couple of post up. I have not install my wheel well sheet metal.
What are the pros and cons of this?
Pros are the splash guards will protect the hoses from any flying debris from the tires, and it also blocks dirt/rocks from getting into the door area. The rear splash guards should also keep the engine bay much cleaner. We were not able to fully install the front splash guards (still working on a good solution) because the tires hit the plate that goes in front of the coolant hoses (and we are running 215's in the front). Fitment is also poor in general and requires trimming.
Tamra
First autocross 3/29/15
^^ Ditto. Keeps things clean, keeps rocks out of things. My Fmod has no fenders and rocks are always getting into the cockpit, the side pods, etc.
Zero Decibel Motorsports
Check out my new website!
Are you running spacers on your steering rack?
I have a similar setup but I had to put spacers on my rack to reduce the amount of steering so I don't rub.
"aerodynamics is for people who can't build engines" - some old dude
"Shut up! I know what I'm doing" - some angry finn
I remember your previous post where you said you had no rubbing after "Over the last couple of weeks we changed ride height, roll center, suspension mounting points. springs rates, shock length, ball joint length, shock bump stops, camber gain and all the alignment parameters."
So which one resulted in no rubbing? lol
Tamra
Tamra and 508wrx
Add 48 ET wheels to the list.
That all worked together to prevent rub, prevent body roll, keep best tire patch, full turning radius, good handling.
When we went on our 40 mile trip, it was pretty harsh on pot holes.
May need to loose some tire pressure.
Dan
Not only did Michael learn how to weld on this project. He can now spray paint and drink at the same time.
OMG, that bumper is massive!
Dan
That is a pretty serious bumper. Are you planning to keep it installed on the car?
Tamra
Today was a pretty good day. Took the 818 back to the state inspection facility with the new bumpers installed.
WE PASSED
I thought we would get our VIN plate today, then to the title office, then to DMV for plates.
But not so quick. The VIN plate has to come from the state capital in Columbus. 3 to 5 days.
So maybe street legal by next weekend.
On the bumper issue. The inspector mentioned that some come in with 3/4" bars. He said "that doesn't cut it".
Future Ohio builders beware.
The Drive.
40 miles at 52F. Tamra, I am getting no engine heat in the cockpit.
About 6-7 people ask me what it was. I told the first couple that it was a Factory Five kit car. They wanted that explained.
Then I change my story to "It's Homemade" They responded "Wow, looks great" the conversation ended as they didn't know what to ask next.
The Car
Gas gauge was at 1/8 so I stopped for gas. Took 10 gallons so there was 3 left, Perfect.
Our 600 lbs rear springs are pretty harsh for street driving.
I'm pretty nervous going down the road next to a semi.
The windshield blocks the wind from hitting you unless there is a decent cross wind.
I need to move my turn signal switch next the shifter.
I can't adjust my side mirrors while strapped in.
235 front tires are wider than needed on the street.
Cop followed me for a couple of blocks with no plates on the car, But didn't stop me.
That's enough for now.
GR8 Bob, Congrats!
Dan
Alright!
whoo hoo, congrats!!!!!!!!
Good to know that the fan in the engine bay helps
Tamra
Thanks Tamra,
I had my fan override switch off. I not sure if they even turned on under computer control.
I scanned a bunch of stuff when I got pulled into the barn.
All temps F and from my weak memory.
Ambient 55
Tires 75-85
Top radiator hose 175
Bottom radiator hose 160
Exhaust wrap right after turbo 350
turbo output flange 475
right fiberglass hump 105
left hump 85
transmission case 125
Awic water hoses 65
I probably scanned another dozen things, but nothing seemed out of line.
Congrats, Bob, on the milestone.
Part of the fun will be the questions &guesses about what it is. I've got to get mine licensed soon!
Congrats Bob. Great to know another one's registered! I know you've enjoyed the heck out of the build, now enjoy the rest.
Congrats! We make our own vin plates in Indiana.
GREAT!
Enjoy it and cope with he "almost nothing to do now" anti climax!!!
Congrats, looking foward to your 818e build.
Well of course Bob! Don't ya' know? All good painters drink---one of the old timers who taught me often had to have someone go in the booth and keep a grip on the back of his shirt so he wouldn't fall into the car while he sprayed! Three sheets to the wind he could lay down single stage enamel like glass
Cool you made it!!
Have fun! A lot of it!
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Michael and I had a great day autocrossing today. The day started of at 54 degrees on blacktop the was resealed this year. It was pretty slick. That afternoon fun run session temp was up to 75 and track was much stickier.
Mike and I got in 21 runs today. The last 9 runs were within 30 minutes. Beat on the 818 and it came through with flying colors.
Here are 3 videos of mikes runs.
Most of our spins in the 818 are only 180 degrees. at the 30 to 32 second mark Michael stayed in the gas and it went around to 270.
Some builders are reducing their steering rack travel. As you see in this video, Michael is using the full 540 degrees counter steer in an attempt to stop the over steer. It wasn't enough.
On the 2nd video with the big spin, I can hear some odd tire chirping right before the spin while Mike's still going straight. Is that the brakes locking up?
Looks like your car is more stable on power than ours, but looks pretty loose on corner entry and lift. Would you say that is accurate?
Tamra
Good ear Tamra.
That chirp is our rear wheels locking up. We have plans for a rear Proportional valve, but that was not high on our list during the registration process.
We were pushing the car pretty hard all day. Michael had the only 2 spins in our 21 runs. But here were probably 100 saves. Michael is getting pretty good at drifting out of corners if break loose on exit. Just have watch out for the outside cones.
I was have problems with over correcting. The tail would kick out and I would get out of the gas and counter steer. The tail would snap back, but I would loose a lot of speed.
Coming out of corners Michael goes to full throttle. At our 225 ft-lbs of wtq, it should give us 0.77 G forward acceleration coming out of corners. To me, this seems to be a pretty good balance. If we crank up the boost, we would have to wait until we are straighter before going full on.
Congrats on getting it registered. I've been catching up on your build and love the creative solutions you come up with.
The wiper solution makes the ffr kit look like a hack job.
Motorcycle has more horsepower than my 818. What was I thinking.
https://ultimatemotorcycling.com/201...-ftlbs-torque/
For the new builders,
The double flaring tool that works, is on sale.
http://www.eastwood.com/professional...ontent=1EM3289
Nice, I think I have only seen $199 before... $189 is great.
Assuming I have no leaks in my system (have yet to bleed it), I should be done with mine. It performed flawlessly. There is just one issue I had with it, and it was my issue. The mandrels have two different sides. They aren't marked on the top (only on the end), so a few times I put the top on 180 degrees off, and got half a double flare plus half an ISO flare. It's very easy to do. I ended up marking the top with an arrow to ensure I didn't keep making the mistake.
