Results 1 to 33 of 33
Thread: FFR MK4 #8634 build thread
    Apr 2015
    Colorado
    Greetings from N. Colorado. Been working on my build for about three months. I thought I would finally post some progress. I must say first, This has been a great experience so far. A project that helps hone all my skills, making new (cobra) friends, getting re antiquated with old friends and seeing this beast slowly come to life. My garage has become the regular gathering place. I have watched these threads for some time now. There are great people, ideas, advice and direction. Glad to be part of this community.
    I first ordered my kit on April 27th 2015. I ordered The base kit, but took advantage of the 50/50. All the complete kit add ons became options so they were 50% off. Saved a bundle.
    Base kit
    powdercoated chassis
    body cut outs
    front lower control arm kit
    3 link sus
    Stainless side pipes
    manual steering rack
    ultralite gauges
    17" hailbrand replicas W/10.5" rear
    wind wings
    Chrome roll bar
    sunvisors
    12.88 wilwood front brake package
    12.19 rear wilwood brake package
    wilwood pedal box
    rollbar grommet set
    hood hinge
    Wiring package
    FFR spindles
    driveshaft
    Originally I was Going to do a 351C, stroked to 408. 4V heads, TKO600. Blue and white. As you guys know, plans change rather quickly. I have sold my 351C block and heads. I have now decided on a 351W stroker. Block is now at the machine shop(fingers crossed it all turns out well). Aftermarket alum heads. I have not decided which, but leaning towards the Edelbrock Vic jrs. Still doing the TKO trans.
    So to get started I had to prep the garage. finished up building my cabinets and mounting the tool boxes. cleaned, organized and got everything ready for the arrival of my MK4
    Great looking shop!
    Here's a couple of threads to help you with posting images:
    How to use the Image Gallery to embed pictures in posts
    How to use an external site to host pics
    I'm looking forward to following your build!
    Apr 2015
    Colorado
    Kit arrives
    On June 29th ,Steve From Stewart Transport arrived with My MK4. He was great. Of coarse my car was last on the truck, but when you wait 20 years to order one of these cars, whats another few days?
    First glimpse of my car
    Apr 2015
    Colorado
    Thanks Dave. Great advise and threads
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Congrats on delivery! I'm just a bit ahead of you and moving onto brake and fuel lines, should be interesting.
    Kyle
    Apr 2015
    Colorado
    Congrats Kyle. Eager to see your progress. I am actually further than this, Just behind on posting.
    Apr 2015
    Colorado
    Next, was braking out the bling
    Hey, There's my keys
    Then getting the body on the buck
    Apr 2015
    Colorado
    Rear End rebuild
    Started striping the 8.8. Got new axle shafts all new bearings and seals. Also got those new fancy carbon discs and shims for the traction lok
    Cut off all the un necessary housing links. Check out the balding head... Nice
    Had to fill in some of the over grinding.
    Striped
    Primed
    Painted single stage Gloss black.
    Built, setting the backlash
    Apr 2015
    Colorado
    Rear done and in
    Apr 2015
    Colorado
    Wilwood footbox
    So, as many of you guys know there is a problem with the Clutch pedal on the Wilwood foot box, hitting the Frame. I notched out both sides(frame and pedal). Hopefully this can help someone in the future. Always grind off galvanized finish before welding that metal...
    Apr 2015
    Colorado
    Double check all new parts
    Ran into issues with the MOSER axle shafts. They were bend at the flanges. Sent them back and got another set from Moser. These were bent even worse. The packing is pure S#$%. The axles have about 4" of space in the box to bounce around. After installing 2 bent sets, I called Moser and spoke with a guy named Brian. He blamed the issue on UPS, When I asked him to pack up a set for me, as I did not want to continue to get bent axles, He said" they would not do that" . I then told him, I would need to return these axles and buy from a company who packages their axles shafts properly, He said, " O.K"
    Got a set of U.S.A alloys. They were perfect.
    https://youtu.be/RmQaSK0C7m0
    Apr 2015
    Colorado
    moving forward
    With the axle dilemma behind me, I could move forward. Got the rear brakes and hard lines in. Pedal box is in.
    Apr 2015
    Colorado
    Fuel tank system
    I was Still waiting for the spindles to arrive so I had decided to install the fuel system. I did decide to drop the trunk floor for a bit more space, I know i'll thank myself later for this
    Poor mans metal brake
    Mocked up
    Apr 2015
    Colorado
    Aluminum panels / heat treat
    While I was waiting on the rest of the front end to arrive from FFR, I began heat treating the aluminum panels. I got some advice from Derald rice. He built his FFR a while back and lives here in town. Very helpful. I picked up some Lizard skin. It is a ceramic coating to help with heat. I coated all the front firewall panels with this stuff and sanded it down.
    Started putting in what panels I could at the time. My buddy Mikey giving me a hand
    Apr 2015
    Colorado
    E Brake
    Under Deralds advice, I also moved the E brake location. Apparently it is impossible to release it when you are full strapped in
    Apr 2015
    Colorado
    Spindles and steering rack finally arrived
    Three months after my kit arrived. My spindles finally made it. So, The front end goes together
    Once the steering rack got here, I was now able to put on the firewall panels and steering shaft.
    Apr 2015
    Colorado
    Visitors
    I must say, It is very cool the first time a FFR pulls up out in front of your house. Derald came by to check my progress
    Those pics are great! Keep it up!
    Quick question: Where are you mounting the battery? I used a hidden battery box from FFMetal on my current 3-link build and it interfered with the aluminum rear axle housing. I had to switch to a stamped steel one instead...
    Apr 2015
    Colorado
    Stop! Shop clean
    I had to stop this weekend to clean and organize the garage again. Thought I would post a few pics of the progress.
    My tires arrive tomorrow. Once I get them mounted I gotta drop this thing on its own 4 legs. Will post more pics
    Apr 2015
    Colorado
    Hi David, Thanks. As far as the battery, I was just thinking about that... I will mount it in the trunk. I would be giving up some space I just gained but, Thats how it goes sometimes. The thought did cross my mind, maybe I'll cut out a section in the upper trunk deck to make a battery box, but I am a bit unsure of the clearance issues I'll have with the rear. I can investigate the clearance further once I get this thing on the ground tomorrow.
    Apr 2015
    Colorado
    Stop! Shop clean
    Apr 2015
    Colorado
    On the ground
    Got my Tires yesterday, had them mounted and balanced and got it on the ground.
    Apr 2015
    Colorado
    Today, I am working on the parking brake. I decided to relocate it to the drivers side and I am using a lever from a 2011. With a bit of cutting it should be a nice tight fit. I need to change the tranny tunnel steel too. I will have to fab up the side and top center console later, thinking 1/4 MDF and fiberglass for the curved contours then vinyl top. I already see how it should finish up on the center console mentally. Hopefully it all goes as planned. I got a parking brake with a leather grip and leather boot. Just got it mocked up right now. You guys see any issues with this location?
    Apr 2015
    Colorado
    Got it mocked up and the new piece of frame tacked in.
    Joe,
    Very interesting brake handle mod. It sure will be in a more convenient location.
    Carl
    Apr 2015
    Colorado
    Quote Originally Posted by carlewms View Post
    Joe,
    Carl
    Hi Carl,
    I think it would be difficult to release the parking brake from the original location once your all strapped in.
    joe
    Apr 2015
    Colorado
    Just for fun
    I have a few more updates, We threw the body on the frame, just for fun. Very cool to see it starting to take shape.
    Apr 2015
    Colorado
    Heads arrived
    Finally decided on the Edelbrock E205, Just came in last week
    Apr 2015
    Colorado
    Trunk
    Got the rear harness in and the fuel filter installed, So, I am now getting the trunk done. I decided to go with 1/4 MDF panels instead of the aluminum. I was a car stereo installer many years ago. Using some of those tricks to finish out the trunk. Once I got all the panels cut, I undercoated them, used nutserts to install them and wrapped them in vinyl. Looking pretty good so far.
    Apr 2015
    Colorado
    More trunk
    [/URL][URL=http://s610.photobucket.com/user/jprocopio/media/20151020_164259_zpstscuxaif.jpg.html]
    Apr 2015
    Colorado
    Brakes/ res
    I also got the reservoirs i wanted. One is for the brake and one for the clutch. I like the reservoir I got with the kit, but I could not find a second one for under 60$. These were $60 for both including the mount. Not bad. I also managed to get the brakes bled and the parking brake fully functional last week.
    Apr 2015
    Colorado
    Radiator
    I wound up going with an aftermarket radiator for a late model mustang 2009 - 2015. It is a good fit. The two upper mount poles have to be ground off and it fits pretty easily. I have to mock up the body anyway so, I can mount the sidepipes so I can fab the headers once the engine is in. I figure at that time I can mock up the lower rad mounts.
    Apr 2015
    Colorado
    Battery
    Hey David, I decided to move the battery to the front. I fabbed up a battery box for the D51 Optima. Thought it would be nice to keep all the trunk space I just gained.
