Results 1 to 24 of 24
Thread: New builder
    May 2013
    Slidell la
    New builder
    I just ordered my kit, I'm planning on a big block fe build. Hope it goes smooth,and I hope I have the patience these other guys on here have.
    Congrats! When does it arrive?
    May 2013
    Slidell la
    Sat March 5th is the completion date
    Congrats. Don't forget to post pics. I am building my MK4 now.
    Fresno, CA
    Congratulations on making the purchase.
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
    May 2013
    Slidell la
    I noticed not to many, doing bb ford builds
    May 2013
    Slidell la
    Is there anything I need to watch out for with a 390 fe install. Like bell housing and/or transmission?
    May 2013
    Slidell la
    Will the t3650 work in the roadster? With the FE
    May 2013
    Slidell la
    I've searched, and I can't find any big block build threads can someone point me in the right direction
    Quote Originally Posted by Hottrodder427 View Post
    Per a post on the other forum, 2005+ T3650's have an intregral bellhousing so you'll be limited to 2004 and older. Also, I believe they're a little light in the power handling department. Especially for a big block build. You should be looking at a TKO600 IMO.
    Not a ton of traffic, but here are threads on the other forum: http://www.ffcars.com/forums/46-big-...adster-builds/
    May 2013
    Slidell la
    I found an 04 t3650 with new clutch fo 700.00, just wondering if I should buy or spend the extra3 grand?
    May 2013
    Slidell la
    Looks like I'll be getting the TKO. What's the difference between 500 and 600?
    Ford TKO-500 is torque rated at 500ft/lbs. 10 spline input shaft with a 31 spline output shaft. 3.27 first gear with a .68 5th gear overdrive.
    Ford TKO-600 is torque rated at 600ft/lbs. 26 spline input shaft with a 31 spline output shaft. 2.87 first gear. 5th gear overdrive either .64 or .82.
    Same exact size, typically the 600 is $100 more. Probably the .64 overdrive 600 is the most common choice for these builds, but you need to consider the whole drivetrain, e.g. tire size, final drive ratio, driving goals, etc.
    May 2013
    Slidell la
    I'm getting the 2015 IRS from factory five, I don't know what the gear ratio is. But Ina just cruise around I. The car prob not more than 150 miles at a time
    The 2015 IRS center section comes in several different ratios. It doesn't come with the kit, but can be added as an option from Factory Five. Is that what you did? If so, did they recommend a ratio or tell you what they were providing? This is kind of a major decision, and makes a pretty big difference in how your build will run and drive. With a big block build, 3.55 or maybe better yet 3.27 would be a good final drive. Anything lower, e.g. 3.73, would be a mistake IMO. But honestly the final decision depends on others things as well, including your transmission selection as already discussed. It all has to be considered together.
    May 2013
    Slidell la
    i ordered the 20 th kit but its coming debadged but its coming with the center section and spindles
    Must not be making myself clear. How about this. You bought a kit with the following rear suspension option: 15942 - 2015 Mustang-based Independent Rear Suspension Kit ($2499). Then added the 16126 - 2015 Mustang IRS Center Section, Spindles, and hubs ($1,400). Those are direct cut & paste from the order sheet. The ratio of the provided center section is not referenced, and there are several different ones available with none considered "standard." That is why I recommended that you need know which one you want and make sure that's what you get. Don't leave it to chance or what they have available. There are also aluminum and iron versions of the center section available. Factory Five first said only use the iron one, but has since said either is OK. But with a big block build, you may want to consider the iron one. The Mustang guys are finding the front mounting ears of the aluminum center section can break with big power and sticky tires.
    And for the record, call yours what you want, but there are only 20 actual 20th anniversary edition kits. They were serialized, special anniversary badging (side badges, floor mats, gauges), special white and silver/grey powder coating, special silver/red Wilwood brakes, and were the first available with its particular option set. It's possible to order a complete kit with the same 2015 IRS, upgraded Wilwood brakes, and many of the same options. I know of a couple that were ordered that way, and now yours is another which is great. But it isn't one of the 20 and not an anniversary edition kit.
    May 2013
    Slidell la
    thats what i was meaning by a 20th and both part numbers ypou listed is on my order email that i recieved from ffr i will contact them and find out what im getting
    May 2013
    Slidell la
    16126 and15942 both part numbers. thanks for the advice.like i said i will be contacting them
    May 2013
    Slidell la
    what drive train are youplanning
    May 2013
    Slidell la
    what drivetrain are you planning
    Apr 2015
    Hey, Hotrodder427 I will also be doing a 390 fe build, just started putting drivetrain together. Ill be watching you.
    Ol Skool
    upstate NY
    Have you guys seen the aluminum block FE available from bear block motors? May be an interesting option.
    May 2013
    Slidell la
    Quote Originally Posted by danpel64 View Post
    Awesome we can learn from each other lol
