Page 9 of 10 FirstFirst ... 78910 LastLast
Results 321 to 360 of 393
Thread: nkw8181's 818 build thread
  1. #321
    Puyallup, WA
    Im referring to the approx 1/2" hole to the right of the output shaft hole.
  2. #322
    Senior Member TX-Lou's Avatar
    Nice work Nolan!
    - Lou
    Building an 818C
    Ordered: 8/31/15, Production Date: 1/23/16, Delivery Date: 2/05/2016
    First Start: 4/14/2017
    818C Build Thread
    Donor Teardown Thread
  3. #323
    nkw8181's Avatar
    Dallas, TX
    I shellaced in a piece of aluminum as shown in the 6 speed addendum. Thx Lou
    Nolan
  4. #324
    nkw8181's Avatar
    Dallas, TX
    Here's some pics of the way we installed the dash as well as making our own center console
    http://imgur.com/a/JkGZL
    Nolan
  5. #325
    Puyallup, WA
    I don't know if its just me but only the first 3 photos load.
  6. #326
    nkw8181's Avatar
    Dallas, TX
    Click on load the other 16 is all
    Nolan
  7. #327
    nkw8181's Avatar
    Dallas, TX
    lets see if photobucket is any better. So here's an update. Got the car tuned and it took a while to iron out an idle issue but appears to be resolved. Josh (touchstone) came over and helped my by wiring up my headlights and another buddy made a stiffer accelerator pedal ( supplied one flexed alot). While I designed a why to use the reverse lockout feature. I thought that the lockout was spring loaded into 6th but it was in reverse so I then designed what I have now which works. I used a door lock actuator and have a button under the left of my seat that you push to get the car in reverse. We also got the center console rapped with vinyl. so here is a video of the tune pics soon to follow
    https://youtu.be/wh5ZExE7vTQ
    Nolan
  8. #328
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Very nice - those wheels look great too. How much power did you put down?
  9. #329
    nkw8181's Avatar
    Dallas, TX
    more pics if you click... I think. 386 rwhp. I'll post the graph in a sec.
    Nolan
  10. #330
    nkw8181's Avatar
    Dallas, TX
    redline is 8k not 7k. the map interpolated it a bit off.
    Nolan
  11. #331
    Hindsight's Avatar
    Atlanta
    386 is great for a 20g on pump gas! Since the RPMs are skewed on that dyno plot, what RPM is peak torque actually hitting?
  12. #332
    nkw8181's Avatar
    Dallas, TX
    not quite sure where the max torque is. also I have a FP 71HTA turbo. the power is limited not by the motor or turbo but by the MAF sensor (hits its limit of 5v if we give anymore boost). I think it is only at 21-22 lbs of boost but no complaints from me!
    Nolan
  13. #333
    386 that's awesome, judging by the quick roll when the turbo kicked in I knew there was more than OEM power in there!
  14. #334
    Senior Member Loring's Avatar
    Nov 2015
    Lakeland, FL
    Quote Originally Posted by nkw8181 View Post
    That hat is awesome.
    818C | Kit delivery: 3/19/16 | Status: Powertrain installed
    Daily: 2014 CTS-V - Fat and slow
  15. #335
    nkw8181's Avatar
    Dallas, TX
    Thanks I'm really excited to get the body on and drive!
    Nolan
  16. #336
    nkw8181's Avatar
    Dallas, TX
    Got the new sti Guage installed and the abs light to turn I off by putting power to i10 pin 18. Blue carbon fiber /kevlar installed on dash and side of doors (still covered in tape. Side sails, nose, front finders instwlled. Doors still aren't quite right and temp installed the rear. I have to pull the bumper back so that it doesn't rest on my shifter linkage. Open to ideas on what to attach to throw mesh where I need to make a pass through for the exhaust. Also trimmed my fuel filler pipe to fit with the Boyd tank.
    Nolan
  17. #337
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looks Great Nolan!
  18. #338
    nkw8181's Avatar
    Dallas, TX
    Nolan
  19. #339
    nkw8181's Avatar
    Dallas, TX
    Thanks Wayne!
    Nolan
  20. #340
    Leesburg, VA
    I noticed you had some sections of metal tubing and couplers from the fuel filler cap to the tank. If you didn't roll a bead on the metal, it may leak fuel when topped off. Those FFR couplers have a generous amount of ID clearance to the metal tubes - I wouldn't call them very snug. I actually bought a bead roller and tried to roll some beads but it cam out not as good as I wanted since the filler tube is stainless and much harder than aluminum. I might get one of these Gates tubes to simplify the number of couplers:
    http://thefactoryfiveforum.com/showt...l=1#post230770
  21. #341
    nkw8181's Avatar
    Dallas, TX
    What about a different coupler?
    Nolan
  22. #342
    Leesburg, VA
    I tried that too, I bought a 2" silicone hump hose and it still seemed a bit too big.
    http://www.ebay.com/itm/51mm-2-Hump-...hSXhey&vxp=mtr
    I wasn't able to find anything that was incrementally smaller like 1.875" ID.
  23. #343
    nkw8181's Avatar
    Dallas, TX
    The car lives!! I took it to a local cars and coffee and had a blast! man it is fun to drive. So here are some pics. I still have a bit to do to but I would say it is 95%.
    Nolan
  24. #344
    Looks great Nolan,
    I really like all the extra louvers.
  25. #345
    Hindsight's Avatar
    Atlanta
    Looks great, congrats!
  26. #346
    Bowling Green, KY
    Nice work Nolan, enjoy
  27. #347
    Administrator
    Enterprise Alabama
    Looks great Nolan
  28. #348
    nkw8181's Avatar
    Dallas, TX
    Nolan
  29. #349
    Senior Member AZPete's Avatar
    Nice work, Nolan! I also got my 818 licensed recently and agree it's a blast to drive!! When someone asks what it is, I ask them first what they think it is. So far, Corvette 2, Lotus 1, Ferrari 1. Since you went to a show, did you get more impressions?
  30. #350
    Awesome job Nolan! It looks great.
    Building an 818C
    818C Build Thread
  31. #351
    Encinitas, CA
    Looks great... how's driving on the street with a R screen? I'm toying with the idea of getting one for my S for trackdays, Sunday drives or just wanting to play Speedracer at C&C.
  32. #352
    Who is the owner of the 818 that was at the April Cars and Coffee? It is orange with black stripes and is in the video on the page link below.
    http://carsandcoffee.com/forum/showt...April-2nd-2016
  33. #353
    Senior Member Solidworks-Mike's Avatar
    Las Vegas, Nevada
    Quote Originally Posted by UnhipPopano View Post
    Looks very close to JJ's build:
    http://thefactoryfiveforum.com/showt...l=1#post225114
    818-S 2.5L Turbo Chassis Number: 404
    Kit Order Date: February 19, 2016 Kit Completion Date: March 19, 2016 Kit Ship Date: March 26, 2016 Build Start Date: April 22, 2016
    Build Thread: Click Here
  34. #354
    Administrator
    Enterprise Alabama
    It should, they're neighbors...
  35. #355
    By neighbors, are you referring to the second 818 behind it? From a comment in one of the build threads it sounded like one lived in North Dallas and the other about 15 minutes away, maybe in Addison.
  36. #356
    Administrator
    Enterprise Alabama
    THey live close together and have shared a bunch of info is what I mean...
  37. #357
    Sep 2014
    Dallas, TX
    It was mine, I was there as well.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
  38. #358
    Nice job!
  39. #359
    nkw8181's Avatar
    Dallas, TX
    I've been asked if it was an S2000 or a MR2 a few times each. Josh and I are the two 818''s furthest along but there are two other 818''s in progress in Dallas that I know of though I haven't met either in person.
    Nolan
  40. #360
    nkw8181's Avatar
    Dallas, TX
    Made the trunk lid so the I can open the engine cover and trunk at the same time
    Nolan
