Woohoo! Now get those aluminum panels installed
Nolan
Yes I've been putting off some of my build until it got registered.
Remaining items:
- Finish aluminum panels, front and rear wheel wells
- Rear mesh
- Replace seats
- finish center console
- Interior carpet
- Paint/vinyl wrap
- Diagnose engine squeak - sounds like its related to the idle air control valve
818S Chassis #288 2.5L 323hp
joshuajach.com
Very cool! Congrats on the TX registration.
(Nolan -- a couple weeks ago, enjoy seeing your car at Auto Science. Very nice.)
Thanks sdrawkcab! Hey Josh did you get your lights to shoot straight of do they still shoot down?
Nolan
joshuajach.com
Last weekend autocross runs.
joshuajach.com
Hey Joshua,
Look like you were having lots of fun. Getting faster also.
I noticed you didn't have to much body roll. What springs and sway bar are you running?
Last edited by TouchStone; 03-16-2016 at 10:21 PM. Reason: fronts confirmed to be #350
joshuajach.com
Its #350 in the front
joshuajach.com
I'm definitely going backwards at this point. My FFR fuel tank leaks around the fuel pick up so I'm trying to fix it with Seal All.
Other than that my goals for the next 2 weeks are:
- Interior Aluminum
- Upholstery and Carpet
- 5-point harness
- New Seats
- Sound System
So far I've pulled the old seats out and cut to fit the center console.
joshuajach.com
Many (including myself) have had the fuel leak issue. Suggest you save yourself the headache and switch to the proper o rings while you have easy access. Solved my fuel leak issue.
http://thefactoryfiveforum.com/showt...l=1#post214070
joshuajach.com
joshuajach.com
Nice gas spring! Will keep that in mind if I decided to do the same.
Very nicely done. (Now to copy)
Nolan
I lowered my tire pressures from 35 to 22 psi for this run. Which gave me a lot more control in the corners. In the fourth run I experienced a loss of power during the straights and now my fuel pump makes a ton of noise and is audible over the running engine. Dropped out of the afternoon heat to make sure I could still get home without a tow truck.
joshuajach.com
Looks and sounds very nice! How full was your tank?
Today it was full. I actually noticed the power-loss the day before and the fuel level was my first thought. The sender was reading 3/8 full so assuming this actually means its empty I immediately filled it up and the problem went away until today. I'm guessing it broke yesterday (either spontaneously or due to starvation) and is quickly getting worse.
joshuajach.com
I wonder if it's the pump itself or an issue with the hose that attaches to the pump inside the tank.... keep us posted. Glad you quit once it started doing that.
Which pump are you running? I've been thinking about picking up Holley's Hydramat to prevent any fuel starvation issues. The autocross runs looked great btw!
Walbro 342
The hydraMat looks promising, would be much cheaper than a surge tank.
For a surge tank install how is the pickup pump protected during fuel starvation? I don't see the point if the pickup can be easily damaged as well.
joshuajach.com
Are you worried about the pump overheating or cavitation?
Zero Decibel Motorsports
joshuajach.com
Cavitation is when the pump is sucking up intermittent air bubbles and fuel. This causes a lot of stress on the pump blades as the mass of liquid fuel between air bubbles hits the pump blades and pulsates. I'm not sure if this is the leading cause of pump damage or the overheating.
With a full or nearly full tank, I'm wondering how the fuel pump pickup could even come into play.
joshuajach.com
I've decided to replace everything about the FFR fuel tank. New tank, pump and sender. So I pulled the old tank out and found a couple of interesting things. First, the tank was leaking from the sender location as suspected even with "seal all" liberally applied. I also did the following test: I drained the fuel tank before removing from the car by connecting the fuel pump to 12v and feeding the return line into a spare fuel tank. I ran this until the pump began picking up air. Then pulled the tank and measured the remaining fuel volume. I had about 1.7 gallons still in the tank! I assume you would need at least double this to cover the pump inlet adequately for driving and more if you want to race.
Tank removed. Had to disconnect the wiring harness from the engine to get the tank out easily. A bulkhead connector at the rear firewall would have been nice in hindsight.
Fuel left in tank after the EFI pump started picking up air. About 1.7 gallons.
Looks like the fuel pump bag filter was folded and only a small portion of the filter was used. I should have also washed out the inside of the tank. Hopefully the fuel filter caught anything that could damage the injectors.
As a bonus this guy need to add more blinker fluid, looks low to me.
joshuajach.com
Looks crap your filter! I tested 35L, I am currently testing 35L in the tank, so far so good, but I had to put A LOT of fuel sealant around the fuel filler tube and use 4 clamps, one is a t-bolt. I am just over the sender hole level and with the sealant I put there a year ago it seems ok. What sealant are (were) you using?
I used "Seal All" http://www.amazon.com/Seal-All-38001.../dp/B0000AXYZG, it says its fuel resistant. I looks like it may have reacted with the powder coating a bit, caused the powder coat to de-laminate and leak underneath it. I'm replacing all the fuel filters.
joshuajach.com
joshuajach.com
Looks good... it is a real pain welding in that spot.
Anyone have issues with the FFR powdercoat? I went to strip off a section of powder-coating to weld on an additional bracket to my frame and shortly after I began sanding the powder-coating flaked off to reveal rusty metal. I hope this was the only spot they missed when cleaning the metal.
joshuajach.com
Its a common issue with ffr powdercoat. I have a few spots that flaked off when I first got the car and most recently right in front of the passenger seat cross bar. I got the $10k kit car comment and its only was a $400 option I believe...
That's the same location I found the rust.
The $10K kit comment is not valid since FFR offer this same powdercoat option on all of their kits. According to FFR video https://www.youtube.com/watch?v=DwLkvBB4RBE the powder coat will last decades and they can offer it so cheaply because they only offer a single color. I don't think FFR applys the powdercoat in house but that doesn't mean they can't increase quality control requirements on their CM. Especially if this is happening more often than not. What bother me most is that the powdercoat will cover up and mask any poor quality work, "What you don't know won't hurt you" right?
joshuajach.com
I disagree with your statement here.
I suspect about 25% (WAG) of frames ship without powder.
The welding guys don't know if it is getting powder or not.
I got both of mine bare because I wanted a different color.
A few very experienced welders looked a my frame and had no problems with the welding.
A single layer powder coat cost me $800 locally.
Form the comment I've heard on here over the years. The comments on bad powder have decreased significantly since the beginning of the 818. I suspect FFR has either implemented a better quality plan for their vendor or their own in house.
I have #181 and my powder coat is really good. There's virtually nothing I have against it. In fact, I have more against the fact that all the welding splatters have not been ground off rather than bad powder coat itself. Nowhere on mine I have seen flakes, except if I accidentally remove powder coat to the bare metal, then yes there are some areas (mostly the brackets in the back) that tend to flake off. POR15 takes care of it.
I'm not saying the welding is bad in fact it looks really good. What I mean to say is that the powdercoat will cover up poorly cleaned metal.
I'm just disappointed at all the little things that have added up related to the powdercoat. On delivery there was a large scuffed area on the roll bar. Welding splatter is sharp and detracts from the look. Now finding rust under the powdercoat.
It basically adds up to the fact that I should have had the powdercoat applied locally.
joshuajach.com
