By Request, we have created a special forum dedicated to the Ford 5.0 Modular "Coyote" motor. This will be your one-stop shop to discuss all things Coyote related.
Enjoy!
Enjoy!
David has kindly taken the time to set up this new forum area strictly for Coyote fitment and development issues. Over the next few days, I will be moving topics that relate to Coyote technical info and tuning. Some of us have started blogs to keep a journal of our own, and if you wish to use this forum to link to your blog, it would be helpful. Again, this is for development issues, not general Coyote chit-chat.
Mark Twain
Thanks David
I actually was looking for someone to ask about doing this. I already emailed the admins on the other forums and they were supposed to be working on it. This will be a great resource for coyote builds in the future... and maybe we can help FFR improve future support.
Wes
It was Joe's idea, I just set it up for him. I like the ability to drill into a topic like this that has relevance across the different cars.
As far as addressing potential changes, I think you would find that this site can change pretty swifty. At least I know the Admin for this site is here all the time.
Thx for this - will be very usefull and reduce the search time for Coyote install items
May want to add the link to the latest Coyote install PDF.
We may also want to consider a post specifically related to the FFR install instructions which need to address: proper fan wring from PCM (direct), speed sensor and inability to connect engine warning light through ECU (need alternate connection (TBD)
Thx
Ah, thank you for mentioning this as I was about to ask for the latest parts list specifically for the Coyote install. Latest installation instructions and installation changes would be helpful too!
(Haven't been here in a while. I was waiting for Dave to post the Coyote stuff when it was finalized. Was also waiting for the SEMA 818 reveal too. Looks like that trip downstairs he took was a long one!)
I'm wiring up my Performance Automatic and the electronics provided by Electronic Overdrive Transmission Controller called Simple Shift. Has anyone done this? I'm doing a '33 with a Coyote 5.0.
Not sure, you may want to check with FFR, I think that is what the Hot Rod Magazine Hot rod has in it.
Tony Zulo would know.
FFinisher/AKA RE63
Does anyone in the southeastern states have a 2016 or 2016 coyote in a roadster that I could come and look at? I have a 2015 that I will begin wiring this Monday and I would really like to look at and talk with someone using this modular motor. I am inBirmingham telephone # 256-476-7058 or 1-205-477-3487. Thanks! Stan
Stan,
Contact edwardb via PM and check out his 20th anniversary roadster build. He is using a 2015 Coyote:
http://thefactoryfiveforum.com/showt...iversary-Build
HTH,
Great idea. Just for the record and a word of caution. There are no updated installation instructions from FF for the 2015-2016 Coyote. The latest Roadster version is revision O, effective date 11/18/15, and it's still the 2011-2014 version. Courtnie from FF recently posted in a thread, and also responded to an email from me, stating they are working to get a new engine and update the instructions. But no ETA at this time. I'm working with a 2015 version, like several others. I think (hope...) I have it sorted out, but it's not running yet. As soon as I get my transmission I'll drop the engine in and should have a first start and go-kart not long after. I know of at least one other build that is claiming about 100 miles on his, with positive results so far. All to say we need to be careful that some issues are specific to each version. I'm happy to share what I've learned, as David mentioned. Lots of stuff in my build thread. I've also got PM's going with several builders.
One other comment, also just for the record. Ford doesn't consider the Coyote a mod motor. It has a similar configuration and some of the internal and external dimensions and bolt-ons are the same. But it's an all new motor, new design, whole bunch of new stuff, and has no common parts to the former mod motors.
Paul, just an FYI - I can confirm that the wiring details you sent me recently are correct for the 2015+ Coyote. Although mine is a 2013 version with the older controls pack, I have been helping a local 33 building using a 2015 Coyote crate motor with wiring that is identical to yours and he successfully did his first start last week!
Kevin
MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
Delivered: 1/6/2012
First Start: 1/19/2014
First Go-Kart: 2/1/2014
Graduation: 1/4/2015
Graduation Thread
Edward's tips are spot on for the 2015 control pack. I have almost 300 miles on mine now and will be on the Hot Rod Power Tour in another week so will be putting quite a few miles on it in short time. Will report back if I have any issues. Currently the only nuisance item is a jump in idle after 10 or so seconds sitting at a stop light. But I can confirm that it has never stalled or even attempted to, runs beautifully.
