Likes Likes:  2
Page 23 of 27 FirstFirst ... 132122232425 ... LastLast
Results 881 to 920 of 1079
Thread: MRG MotorSports 818S Build
  1. #881
    Senior Member metros's Avatar
    NoVA
    One more short video from our Great NCM Weekend.
    https://youtu.be/xVEqS3Gs9SM
    Looks like a fun track with a lot of elevation changes.
  2. #882
    Second big swing at suspension set up.
    As a result of doing track days this year, as opposes to autocross last year, we are going at higher speeds.
    The car was nervous at high speeds and has some snap oversteer.
    Changes this time:
    600 to 500 rear springs.
    2.5 to 4.5 degrees castor.
    -0.5 to -2.0 camber front plus 1 degree per inch of travel camber gain.
    -0.5 to -2.5 camber rear. ( never measured the camber gain in the rear)
    Added BEAR bump steer kit.
    The included washers with the kit were not enough. I had to add a couple of washers for a total of 0.952 spacers.
    I also added a safety washer to the bottom.
    We will be testing tomorrow at Grissom AFB.
  3. #883
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    I think those changes should help a lot. Good luck tomorrow and report back!
    What is your rear toe set to? That can cause a lot of issues too.
    Tamra
    First autocross 3/29/15
  4. #884
    front is 1/8" out and rear is 3/16" in.
    I suspect our big problem was bump steer. We were going from 1/8"out to 1.5" in during 2" bump.
    So during a left turn, the car would roll right causing the front right to dig in and throw the back end around.
    That's my theory and I'm sticking to it.
  5. #885
    Bowling Green, KY
    Bob, I will bet the car will be MUCH happier, have fun tomorrow.
  6. #886
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Good luck and let us know.
    I just noticed the aftermarket wheel speed sensor you have there... what's that for?
  7. #887
    Speedometer. We are using a 2012 transmission that doesn't have one. 5 pulse per rev on 24" tire is perfect.
    http://thefactoryfiveforum.com/showt...l=1#post236077
  8. #888
    Sep 2015
    Hamersville, Ohio
    I think I'd try either 0 toe in for the front or else up to 1\8" toe in. Toe out is very twitchy. Suit yourself.
  9. #889
    Apr 2014
    Shelton, CT
    Sounds like you are on the right track, Bob! Rear toe in of 3/16" is good. I bet your issue is bump steer like you are thinking, so hopefully that fixes it. We run toe out up front too since it sharpens up the front responsiveness, but too much can make it twitchy like Lance said.
    Tamra
  10. #890
    Our big swing at suspension change ended up being a foul ball.
    Changes this time:
    Biggest problem was the large camber changes caused the tire to run on inside edges.
    Braking sucked as front tires were only using 2/3rds of tire.
    Oversteer was difficult to control. Overall we were not happy with this setup.
    Michael and I a both hurting and sore tonight. The car was beating us up.
    We tried to use gopro mounts on an galaxy S7. Another fail. The heavier S7 was vibrating all over the place. Also the camera position was bad as the it need to be about 6" lower.
    https://youtu.be/hEzZTINaKWg
  11. #891
    Sep 2015
    Hamersville, Ohio
    Large camber changes cannot be escaped with short a arms.
  12. #892
    Apr 2014
    Shelton, CT
    Hey Bob,
    Did you happen to mark the tires to see where they are rolling over to (to see how much of the tire you are using in turns)? The camber up front will definitely hurt braking grip. However, in corners, you should be going from using 2/3'ds of a tire to 100% if your camber is correct, which should result in maximum grip. We are running -3.5 in the rear I believe, and found that we were wearing the tires evenly at autocross. A bigger handling difference for us came from adjusting rake - we lowered the rear ride height a touch and the car became much more manageable. When you replaced the springs, could you have changed the rear ride height by any chance?
    Did you happen to keep an eye on tire pressures? Some cars are very sensitive to tire pressure changes. I know in a track session you can't check/adjust them as frequently like in autocross, but it may be a good thing to keep an eye on in case you need to adjust your starting pressures/ pressure bias. Sometimes even 1 or 2 psi can make a big difference. Maybe some other track day guys have more feedback.
    Tamra
  13. #893
    Hey Bob,
    Hi Tamra,
    We just went too big on our camber changes. Our tire wear was perfect before on the set up we were running for the last 6 months. Took a set of R888 down to slicks with no cord showing.
    We did not have our tires chalked at the beginning of the day. But I did have the tires clean. We were 1" to 1.5" from the arrows.
    Our static camber setting will be less than most because we have other changes that increased our camber gain and have less body roll.
    After changing springs we did set our ride height back to 4.5 with 600 lbs payload in the car.
    Our tire pressures started at 18f/19r. With a 2 person car and a small crowd. There wasn't any time to do much between runs. Feeling our tires between runs, they were maybe 120F. Our tire recommended temperature is 180f.
    New plan is to stay with the new Caster and bump steer setting an drop the camber setting to 1.0f and 1.0R and try again next weekend somewhere.
    Then a week from today we will do a track night at Putnam.
    http://www.tracknightinamerica.com/e...ndiana-june-13
  14. #894
    Apr 2014
    Shelton, CT
    Hi Tamra,
    Our static camber setting will we less than most because we have other changes that increased our camber gain and have less body roll.
    If your suspension geometry changes made it so you have increased camber gain, then I think you're right and reducing your camber would be a good idea.
    Have you calculated how much more camber gain you have now relative to the stock setup? For example, with us running -3.5 static in the rear with the same spring rate as you, do our car's camber curves cross each other at some point through travel (ie do you end up with more negative camber during max normal compression than we do, despite us starting with more)?
    Tamra
  15. #895
    I haven't looked a the rear in a long time.
    The front is now giving us about 1 degree per inch of upward tire travel.
    I don't remember what it was before.
    Maybe I should do an excel sheet to see what is going on.
  16. #896
    Mileage on our 818.
    This is my estimated miles on our 818.
    Street/Road miles: 3000 Mostly drives through country and Michaels to/from high school.
    Autocross Miles: 300 miles on 500 runs. Very hard miles, Full gas -- full brake-- 1.2 G turns repeat about 25 times per one minute run.
    Track Miles: 800 miles, 4 track days with 3 hours on track each day. About 40-80 in turns and 80-120 on straights.
    Trailer miles: about 3000 to and from autocross and track events.
    Cost: 2.5 years spending a lot of time with my son: PRICELESS
    Talking about trailer miles. This was our tow vehicle for the last few years:
    Time to add a second TOW vehicle. 2005 High mileage Suburban Z71 4WD (250K)
    Loaded up heading to another track day at Putnam Park Raceway tomorrow. Over by Mechie3's house.
    Michael is already telling me that the Suburban is his.
  17. #897
    Hindsight's Avatar
    Atlanta
    That's an awesome tow vehicle Bob. I have no tow vehicle so am going to be very nervous when taking my 818 to the drag strip and road race courses. I could always rent a uhaul pickup and car trailer but that can get expensive.
  18. #898
    Bowling Green, KY
    Bob, How did the car work at Putnam Park with the revised set up?
  19. #899
    "Track night in America" is tonight. I let you know tomorrow.
    Her is what we are testing:
    cold tire Pressure: 18F/19R
    front springs: 350
    front ride height: 5"
    front caster: 4.5 deg
    front camber @ RH: -1.0 deg
    bump steer : 0"
    front toe : 0
    rear springs: 500
    rear ride height 5"
    rear roll steer 0
    rear camber @ RH -1.5 deg
    rear toe: 3/16 in
  20. #900
    Sep 2015
    Hamersville, Ohio
    Sounds like that setup should work real well. Good luck!
  21. #901
    Bowling Green, KY
    Have a blast, should be more comfortable for sure,
  22. #902
    Great success today
    Today we went to a SCCA Track night at Putnam park.
    Finally we got our handling issues under control.
    With no aero, our 818 was very balances, braking was good, tire wear looked even.
    Very happy with the results today.
    Also, this was our first track event with the temperature around 90. Our fans didn't com on until we were off track for a few minutes. So our nose mounted radiator is working out.
    We did have some issue with our data logger and videos. In this video the movie is not synced with the g force, GPS and speed data.
    We are in the novice group which is passing with "point by" only in the designated zones.
    Michael only gave one point by in over an hour on track. That was only to get to a place on the track with no traffic so he could open it up.
    https://youtu.be/qyTCXsdPObE
  23. #903
    Hindsight's Avatar
    Atlanta
    Awesome Bob! So cool to watch him reel in and pass cars that cost several times as much as the 818.
  24. #904
    Bowling Green, KY
    Great news congrats, I can tell by Michaels hands the car is much better.
  25. #905
    Looks like we lost our gas cap.
    Is FFR still replacing these.
    I might use that hole for the dipstick.
  26. #906
    They should. They replaced mine not that long ago.
  27. #907
    Good job Michael & Bob! Fun track isn't it I've run Putnam several times and would liked to have joined you for Track Night in America but alas the organizers do not approve of the FFR roadster's roll bars...
    Hi Jeff,
    Yes, it is a fun track.
    We are scheduled to do a 2 day Track Day there on June 25-26 with 10/10th Motorsports. So I'm not going to make it to the London Cobra show to see you get your award. Congratulations.
    We put a bigger roll bar on our 818S for our own safety. Track Night in America wasn't enforcing roll bar rules as you can tell by the S2000 that was in front of us in grid.
  29. #909
    Look what was parked in front of my employer's work shop today.
    Divergent 3D Super Car
    700 H.P
    1400 LBS
    0-60 2 seconds
    3D printed aluminum body
  30. #910
    I like the concept and would like to see it applied to custom parts. As far as the specs go, "and blazingly fast (zero to 60 in 2.5 seconds)."
  31. #911
    ... Track Night in America wasn't enforcing roll bar rules as you can tell by the S2000 that was in front of us in grid.
    Actually Bob TNIA says that is OK---guess they figure that the S2K or Miata windshield frames will keep the cars off your head but my pair of 2" by .120 DOM steel bars won't. Go figure...
    I've run Putnam with 10/10ths. They have a great program, some really good instructors and get you loads of track time. Have fun!
    Dec 2014
    north east ct
    bob I have a gas cap if you need one pm me with an address brian
  33. #913
    Quote Originally Posted by brian b 36 View Post
    Thanks Brian,
    Once Tony gets back from the Power tour. I will see if he's got one for me. If not I'll take you up on your offer.
    http://thefactoryfiveforum.com/showt...l=1#post240769
  34. #914
    Dec 2014
    north east ct
    ok I have 2 extra new ones I got the new tanks and they both came with gas caps
  35. #915
    Central CT
    700 H.P
    1400 LBS
    0-60 2 seconds
    Good grief! How long till 3d printing comes to FFR products?
  36. #916
    Hindsight's Avatar
    Atlanta
    Quote Originally Posted by snowphun View Post
    I think the headlight buckets are 3D printed.... not positive though.
  37. #917
    Mechie3's Avatar
    I think the headlight bucket prototypes were 3D printed, but the final ones certainly look to be vacuum formed.
    Zero Decibel Motorsports
  38. #918
    Somewhere on the internet [http://www.gcreate.com/#!factory-five-racing/ccwc] is the story on FF purchase of the 3D printer. The article stated that for showing the original car they printed the first set of lights. The article did not identify how big a part their 3DP can form, but I am under the impression it is larger than the Head Light Buckets. and smaller than the fender it attaches to.
  39. #919
    I believe, they printed out the mold for the thermal form buckets.
    I have fiberglass and thermal formed buckets for the original headlights. They fit each other like a glove.
    I concluded that they are using fiberglass or printed parts to create the thermal formed parts.
  40. #920
    Sep 2015
    Hamersville, Ohio
    I got my headlight buckets a couple months ago and finally took a good close look at them. They don't fit the contour of the fender worth a darn. Does anyone know what type adhesive to use to attach them to the fenders? I'm going to do a little grinding on them to close the gaps but there just isn't enough thickness there to close the worst areas and still have a flange to glue to.
