Results 1 to 20 of 20
Thread: single wiper solution
    Mar 2015
    Belmar, NJ
    I posted a video showing a marine wiper I installed. It was very easy mounting and wiring. Clean and takes up very little space
    https://youtu.be/ajLQ1Svzpqc
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
    Feb 2014
    Wellington, New Zealand
    Very tidy. The best that I have seen.
    I used a wiper off a Mercedes C280 that works well but took a lot of effort to get it right. It tucks neatly inside the bonnet with just a bare minimum of trimming needed.
    Cheers
    GEP
    Senior Member Buzz Skyline's Avatar
    May 2013
    Greenbelt, MD
    Nice! I did a single wiper too, but it's not nearly as tidy as yours.
    What are you going to do (if anything) about the wiper fluid sprayer?
    Feb 2014
    Ramona, CA
    great, simple solution.
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Seems like a lot of folks are doing single wipers without having to cut the hood. On mine, my hood sits quite close to the windshield. It nearly touches at the corners of the hood so I had to trim the returns of the hood down there, that that only extends maybe 3" inward from the outer edge of the hood.
    Probably this weekend or next, I need to start working on the wipers as one of the final things I need to do in order to pass inspection and get on the street. I don't want to cut the hood. I have a remote master cylinder which is in the way of my pushing up the hood toward the back. I guess I could push it up further back, from the frame. Not sure I will get the needed clearance that way though. Anyone done it this way? If so, did you lift the back corners of the hood at all to help clearance?
    Mar 2015
    Belmar, NJ
    I fabricated a stand off that raises the hood so I have the clearance I need. I put some of the bubble rubber molding on it IMG_0380.JPGIMG_0381.JPG
    Feb 2014
    Ramona, CA
    Quote Originally Posted by insurance guy View Post
    I did the same thing with the hood support. The hood really moves around, at +50mph, with out it.
    Then I have some hood pin extenders that I can have the rear of the hood up another ~1.5" up, to clear wiper arm; for temporary use.
    Hindsight
    My hood is mounted normally and I did not trim the returns. My windshield is mounted back and down all the way.
    https://youtu.be/U-HMdbagCuE
    Probably have used the wipers a dozen times driving the car in the rain.
    Freeport, ME
    I used the subaru wrx piece with one arm. I didn't cut the hood but the returns are shaved pretty thin where the hood sweeps, I did use a hood support made out of 1 x 1 aluminum stock with an adjustable height bumper from ACE on the top. There is a wiper thread with all sorts of details. It can be done...
    Dan
    Hindsight's Avatar
    Atlanta
    Thanks guys - gives me some good food for thought. Really hoping I can tackle this over the weekend. Am trying to get the lights wired up tonight.
    Great day to test the wiper out.
    just out for drive to solve a motor issue.
    Just happen to take a video on the wiper in action. This is a long video, sorry.
    http://thefactoryfiveforum.com/showt...l=1#post211128
    For those who raised the hood, did you raised the fenders as well to match the hood's height?
    May 2013
    Greenbelt, MD
    I didn't. I included a support under the center of the hood to provide clearance for the single wiper, but left the rest of the hood alone. It bows up a little, but is not noticeable. Also, it makes the hood very stable and eliminates the floppiness it had before I mounted the wiper.
    May 2013
    Greenbelt, MD
    I had to move the fenders in slightly where they meet the hood near the windshield to account for the mild bow in the hood, maybe 1/8 inch or so, as I recall.
    Senior Member AZPete's Avatar
    On this forum it always amazes me how many ways there are to skin a cat. . . or mount wipers. I also used the donor mechanism and modified it for one arm, didn't cut the hood but used a center hood brace. I've enjoyed seeing how many variations there are, so here's another one.
    I like it! Lucky guy.
    Harley818's Avatar
    Vancouver BC
    There are two threads on single wiper....
    One under body, the other under general. we should consolidate or combine them.....
    http://thefactoryfiveforum.com/showt...868#post243868
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    I agree. We miss posts too easily otherwise.
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    I have a lot of pix on my wiper - so link to it here, post 218
    https://thefactoryfiveforum.com/show...554#post403554
    Aug 2019
  21. Likes DSR-3 liked this post
