Results 1 to 10 of 10
Thread: Nut sert tools
    Burlington, WI
    Nut sert tools
    I have been searching tool suppliers for some good quality nut sert tools which won't break the bank. But, I thought I'd see what you all are using and recommendations. I'm sure some work better than others, and curious as to favorites. In particular, I am looking for ones that can handle 5/16" inserts.
    I use these real simple and relatively inexpensive tools from McMaster. This is the 5/16-inch size. https://www.mcmaster.com/#96349a407/=14toizc. Work great and bullet proof. I have this size and the 10-32 size. Does everything I need.
    "The I.E." SoCal
    I made a tool similar to this. I have multiple holes in it for different size nutserts and use it all of the time. A stack of washers with some lithium grease works as a bearing for the bolt to spin and pull the nutsert in. For those nutserts smaller than 1/4" I even use a 12 volt impact driver to draw the nutserts in with this tool.
    https://www.youtube.com/watch?v=U86ew0FcC1I
    __________________________
    I followed EdwardBs recommendation and purchased some of these as well. They work great. Highly recommend.
    Burlington, WI
    I have had more than my share of questions lately and really appreciate the responses and assistance. What a great community.
    Jay
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Jay - I made my own... happy to talk to you about it if you'd like. Plus, I can drop it by your house and you can copy it if you want.
    Later,
    Mk3.1 #7074
    Burlington, WI
    Chris,
    I'm always up for a challenge, so watch for a nice weekend and head my way. It's getting cooler out so that may be tough. I dropped the engine in for the final time, and always open to suggestions.
    Jay
    I've used Jay-Cee Sales for many years.
    If it is a rivet, rivet nut, thread insert related, they will have it.
    248-478-2150
    http://rivetsonline.com/
    I own this tool https://www.menards.com/main/tools-h...41915888690140
    Has worked for everything on my 818 without any issue.
    Some pics of my home-made version. This worked great to add rivnuts for the seat pans and a few other places where I used fairly large rivnuts.
    Later,
    Mk3.1 #7074
