Thread: 5 Point Harness Mounting
    Des Moines, IA
    Curious how others have mounted the lower part of their 5 Point harness (Lap and Sub Strap)?
    Feb 2013
    Westminster, MD
    I'm assuming you have an S?
    Mechie3's Avatar
    Indianapolis
    I have some pics in my build thread. I added some anti crush tubes and welded them into the X bar for the sub. For the side I made some angle bracket mounts, welded them to the frame, and bolted to that. I think Metros also has some pics.
    Zero Decibel Motorsports
    Check out my new website!
    Des Moines, IA
    Yes. It's an S. I decided to weld in some angle iron. Thanks for ideas.
    Kirkland, WA
    Quote Originally Posted by SixStar View Post
    The R has tabs for all 3 lower belts -
    The center one on the R did not work out for me, I had to cut it off and go to floor area.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Syracuse, NY
    Same thing for me. The position FFR puts the sub mount is way off. You can see how far I had to move it to be in the correct position.
    MK3.1 Roadster completed 2011
  7. Likes Scrmblr2 liked this post
