114
679
With the help of my wife, we got the rearend installed this morning...diff, UCA's, LCA's and shocks. IMG_3264.JPG
Want to throw out a couple of questions. I have come across (several times now) what I am calling "hanging instructions" in the manual. For example, with regards to the assembly of the rear shocks at the lower mount...FFR manual states on the passenger side, place the large spacer in front of the shock and then the 1/8" spacer behind and then they never mention the driver side. So do you assume it gets installed the same way or opposite? I went with the same way as after trying the other way there would be interference with the shock and the frame. Would also like to know if there is anyone out there that has gone with the upgraded koni's and if they actually can be installed body up? No mission critical items as I will follow up later this week with FFR, but you'd think after 1000 of these the manuals would be pretty iron'd out
Will try for the rear brake install later this evening.
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
