Results 1 to 15 of 15
Thread: Cup Holder instalation
    So. Bay (So. Calif.)
    For those with cup holders in the trans tunnel top, how did you install them to keep them in the hole? And what position/location did they end up?
    The 4 ideas I've come up with are glue/HSRF/JBWeld, build a bracket underneath, friction push in, or plane old gravity. All have advantages, and unfortunately disadvantages. I'm also making the trans tunnel top aluminum removable, so the fact that it has to move forward and aft for install/removing, and the cross bracing of the 3/4" tubes is another design issue I'm trying to solve. It looks like the cup holders will be straddling the forward cross brace, and be right up next to it, which means it will restrict the forward/aft movement with the cup holders installed, necessitating the aluminum may have to go on first, then the cup holders drop in. I think. Maybe.
    This (picture) is what I'm thinking at the moment.
    The more ideas the better. Thanks all. Pictures if you got 'em
    I put cupholders in my Mk3 first build. They were relatively shallow and in the same general position you show. But that build was a T5, so more space than a TKO where it can be a little tight. You'll need to figure out where they fit best for your build. But they need to be firmly attached. Gravity definitely won't due. There's pretty strong positive air pressure in the transmission tunnel. I've read of several instances where guys had them pop up or fly out completely due to the pressure. For mine, I put a heavy bead of RTV on the underside where they came through the cover.
    Thanks Paul. Yeah, these are the small one's from Watson's Streetworks. They have about 1/2"+ vertical clearance from the top of the TKO, so that will work. Just can't quite push the trigger on the hole saw yet, trying to figure out location, then attachment.
    I had similar cup holders to those pictured in your post. I placed them on either side of the diagonal brace behind the shifter on the TKO600 rather than in front of the shifter. My reason for this location was to keep water bottles out of the way of the shifter and the forward throw. The holders are staggered as opposed to being beside each other. After one season, I took the original aluminum holders out and put in some larger diameter marine stainless steel units. The aluminum holders looked terrible after one season with scratches. The new units are designed to hold a "Koozie" (which helps to keep water cool a little longer), but also have a smaller recess for coffee cups. The holders are NOT secured in place. The hole in the aluminum trans cover is precise and allows for a friction fit. No glue... no silicone...no mess. KISS!!! In addition, being able to remove the holders makes it easy to clean the spilled dried coffee.
    I like having the cup holders. They also serve as a good spot to put the phone and wallet when there isn't a water bottle in them.
    Ohio
    There is room between the shifter and the rear bulkhead for a console with cup holders included. Got mine at cupholdersplus.com. It's called the drinkster narrow bench seat console shorty. I did modify the rear to match the angle of the rear bulkhead wall. Not too difficult. Nice to have an armrest too although it does set back some.
    JRL16
    I put a pair in a car I built for a customer:
    No glue; like Dave's simply a precise fit with the carpet and insulation pie cut and tucked into the hole. Actually takes a bit of effort to push them into the holes or pull them out for cleaning. These sure as heck aren't gonna' get blown out by under car air pressure!
    Quote Originally Posted by JRL16 View Post
    Any Pictures? Permanent/fixed or removeable?
    It's hard to tell from the picture angle: Are they between the two cross braces, or straddling the forward cross brace?
    Sep 2014
    Farmington, Maine
    A better question might be, how do you keep from spilling the contents? The urge to "git r done" is never preceded with, is my coffee cup secured in it's holder Just kidding of course, but make sure you use only positive seal cups. I am sure someone out there had spilled their morning coffee.
    Ohio
    Correction on that console name. It's the short bench seat cruiser console. No pics yet. It's a nice fit though. Sorry about that. Too many irons in the fire.
    JRL16
    Ohio
    https://youtu.be/cbbJa3_Fn1c Here's my youtube link. Hopefully it works
    JRL16
    Ohio
    I put some nutzerts into the aluminum under it. The fasteners are covered by the material on the bottom of console storage area. Rock solid.
    JRL16
    Mar 2013
    Fort Collins, Colorado
    I REALLY REALLY REALLY like my magnetic cup holders. No worries about where the bracing is, and when I take them out, there is no evidence that they were there in the first place. Dont know if this is allowed, but here is the thread from the other site:
    http://www.ffcars.com/forums/17-fact...glove-box.html
    Senior Member karlos's Avatar
    Littleton, CO
    Looks like the locations you're planning are the same as what I ended up with. Clears the crossmembers and the top of the TKO600, but not by much. Wouldn't know how to act if something wasn't a tight squeeze
    As far as retention goes, a big fat silicone O-ring works great. Holds tight but can be removed from under the car if absolutely necessary. About $1 a piece from eBay (link provided below). Not sure what size you might need. I went with a 2-7/8" ID O-ring to fit a 3" OD cupholder. Has to be stretched somewhat to fit, which keeps it from falling off.
    http://www.ebay.com/itm/FDA-SILICONE...oAAOxyUrZSp6SA
    The O-ring retainer is a great idea. I'm going to remember that. My comment about making sure they are firmly attached and could come out under pressure was maybe overly dramatic. It's not like the transmission tunnel is an air compressor tank. But I was mainly responding to the possibility to have them in with gravity only. They will lift or even come out if installed that way. They need something holding them in place.
    My cupholders are held with two hose clamps each, attached end-to-end. Don't thighten too much otherwise the cupholder will dent.
