I've rarely seen mentioned on the forums about periodic maintenance on the cars. This would include any of the Factory Five models. My purpose of this thread is to ingrain in each and every one of you that these are race cars licensed for street use and need to be treated as such. Every year, this being our third, Julie and I join a group that spends a week cruising the country. These past two years we have done Utah and Northern California. Each year before these trips I take the time to go through the car, back to front, and check every nut and bolt on the car to make sure nothing is going to come loose. I did my yearly check this past weekend. We had just returned on Saturday from a memorial service for one of our fallen members and I was just having trouble relaxing, the recliner really wasn't doing it for me. I had noticed a noise coming from the rear passenger side as we were pulling into the driveway so I had a second reason to check things out. I did my normal routine starting at the rear of the car. I got to the rear right caliper and found the caliper bolts both top and bottom were loose. The bolts were installed with blue thread locker when the car was assembled and checked out every time over the past few years and had never loosened before. But here they were, backed out at least 4 full turns allowing the caliper to rattle when the brakes were applied, curious. I went ahead and removed them, cleaned the old thread locker off of them, reapplied new thread locker, installed the bolts and torqued them. Now keep in mind, not one other bolt in the entire car had to be re-torqued this time, they were all right where they were as I had left them the last time they were checked. I think many of us take for granted that these cars take maintenance. We concentrate on building horsepower and torque, sometimes without remembering that a $2 part can and will end a good time in the car in a split second. Here are some of my thoughts on how to maintain your car, whether it's a Factory Five or not, remember it IS a race car.
1.-Nut and bolt the car at least once a year, more often depending on how you use your car.
2.-Scale your car at least once after you get it road worthy or promptly after purchasing a completed car. And every time a suspension part is replaced, remember to disconnect your sway bars before scaling.
3.-I've seen more than my share of brake threads on the forums with varying degrees of success when it comes to finding a brake package that works well and is predictable. Continue to adjust and upgrade your braking system until it stops the way you believe it is supposed to. It should at the least be able to repeatedly out brake your daily driver. (Note that corner weighting /scaling the car can increase the brake performance).
4.-Grease,grease and more grease. The suspension parts on these cars work best when well lubricated. If you have hiem joints, check them every year as well and make sure the Teflon is in good condition.
5.-Most important IT'S A RACE CAR, remember that!
I will say that crawling under the car in past years to do these maintenance routines has been a bit of a chore. Now having the 4 post lift I can get the session done in about an hour, including an oil change. Spending the 2 or so hours in the past still is a small price to pay for the smile on the face factor you all know when you get out on the road or the track.
