![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
I thought I had a good understanding of the fuel system.
Since all fuel systems for our Subaru engines are designed to hold a constant 43.5psi of differential pressure.
Why is a tune needed if a pump or regulator in the fuel system is changed?
Sounds to me like your covering up a fuel system problem with a tune.
PS: I have a OEM jet pump on my return line that has restriction. I could see this causing a problem if I would go to a higher volume pump.
