Today I started laying down the Cool Mat. I completed the firewall and PS foot box.
There is a huge difference in sound transmission on the insulated panels. I hope the heat insulating benefits are just as noticeable.
Delivered: 6/17/2017
First Start: 12/30/2017
Completed: 12/7/2019
Legal: 1/30/2020
Member of the The Gateway Cobra Club
BluePrint sent me my dyno numbers today and I plotted them out.
Legal: 1/30/2020
Legal: 1/30/2020
Today has been a good day. First, my engine is on it's way and the dyno results look good. Then, my leather door panels from Herb Fraser (cobraherb) arrived and they look fantastic!
Legal: 1/30/2020
Papa I just discovered your build thread! You're doing a very similar build plan to what I would like to do (347 efi from blueprint) Looking forward to following along! Thanks so much for taking the time to share your experience with the group!
"Gravity, It's The Law"
Legal: 1/30/2020
Standing by! - Popcorn in hand!
Legal: 1/30/2020
Legal: 1/30/2020
We were A-Okay and just had a little tide water in the streets from Lake Pontchartrain.
Legal: 1/30/2020
I only got to work on the car today for a couple of hours, but made some progress just the same. I re-routed my front harness per Paul's recommendation.
I also wired up my gauges to the dash harness.
Legal: 1/30/2020
Today I insulated the DS foot box and set my dash into place. I installed the ignition, horn, and headlight switches.
Legal: 1/30/2020
Papa
I always thought that there where 0011 types of people in this world
Those who make thing happen
those who watch thing happen and
those who wonder what happened
I like the door panels from Cobra Herb that you posted about, I am planning on ordering a set in a few weeks.
Looking through your pictures and the power steering install does the rack have the 1 inch rack extensions installed?
Your build looks great
Rick
Thanks for the kind words. My steering rack was ordered with the kit from FFR and does not have any added extensions. Each rod is a single threaded piece. On the door panels, I wanted leather and you need to supply your own with your order. I found a full hide on eBay for $150 and the grain, color, and finish is an exact match to the leather seats. I sent Herb what he needed and still have over 1/2 of the hide remaining.
Legal: 1/30/2020
I sent you a PM regarding the left over hide.
Look what showed up today!
When I ordered the engine I wanted the "Cobra" valve covers. I didn't realize they would have the 427 on them. I may be looking to do a swap at some point. I don't want to be accused of posing.
Legal: 1/30/2020
You would have got a lot more done if it were not for me showing up and asking 120 questions. Your build is looking great online but out of the park in person. Thanks again for letting me drop by on Sunday. A most gracious host letting me take well over an hour of your precious build time.
The motor looks amazing. Give me a ring when you are ready to put it in I would be happy help. Many hands make small work.
Ron
Legal: 1/30/2020
I wish that factory five would have had the power steering option when I ordered
mine back in 2014 it would have saved me time and money
I miss read you thread about the headlight dimmer I thought you were taking about the
switch not the driving lights my bad
Love the motor pics should be one bad *** mkiv when you get it completed
Rick
Papa,
Very cool looking engine. That thing should awesome. Is that a vacuum advance on your distributor? I don't have that. I am pretty new when it comes to the engine stuff. Well, actually I am new to all of this. What am I saying? Did you specify that on your engine or just standard from blueprint? Just curious. If you don't mind, let us know if you like it and what it does for you.
It does have vacuum advance on the distributor. I didn't specify anything other than the 347 with EFI and power steering and the transmission option. I haven't had a chance to really look it over yet. First step will be to go through the EFI package and start finalizing my fuel system.
Legal: 1/30/2020
If you are using a march power steering sagnaw style pump you can get a kit part number p306 to set the pressure without having to install an external regulator. You add shims to the built in regulator to set the pressure.
Legal: 1/30/2020
Looking at your motor pics it looks like you have a march accessory kit
If that is true then the power steering pump is most likely a sagnaw type pump
From my crash course in power steering gear type steering units operate at around
1200 psi rack and pinion units operate at less than 1000 psi
Pressures greater than 1000 on a rack may cause the seals to fail
If your pump is a sagnaw style pump you can use the p306 kit to set the pressure
I set mine to about 700 psi it provides good assistance at low speed but
doesn't feel to light at highway speeds
Rick
Is this what you are referring to?
https://www.amazon.com/Performance-P.../dp/B000PHJ6X0
How/where does it install and how does it basically work to regulate pressure?
Legal: 1/30/2020
Papa ...
The engine is beautiful ... this car is going to be a real winner.
Congrats,
Carl
See if you can read this I found the instructions
If it is a march sagnaw pump there should be a large nut with a fitting in the center on the back of the pump which is the discharge port
Legal: 1/30/2020
The flow valve is under the nut you can use your finger or something to pull it out
Hope this helps i had to look for a while before I figured it out
Rick
Are you going to do a mid shift on the tko there is a kit that doesn't require you to take the transmission apart to install I found it by dumb luck you just have to remove and reinstall a couple of roll pins
Hey Papa, I happened to notice your serial # is 9754. Is that correct? I ordered mine after you and mine is 9158. Maybe I'm reading mine wrong? Just wondering if yours was actually 9154?
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022, First start 6/13/2024, Go Kart 8/19/2024
Serial #9158
Legal: 1/30/2020
Today I worked on figuring out how I would install a floor-mounted headlight dimmer switch. I wanted to mount it in the lower left of the foot box in a way that would not interfere with the clutch pedal. I then made a template for a bracket.
I picked up a small sheet of 22 gauge mild steel at my local home improvement store and traced the template onto the steel and then cut it out using a cutoff wheel. I don't have a bending brake, but was able to use my vise and made the bends using just my hands.
Once I was happy with the fit, I drilled a hole and mounted the switch from behind with nutserts.
The final assembly will be attached to the foot box tube with button-head screws into tapped holes and likely just a few pop rivets around the perimeter. The wires will come out of the bottom and then up into the foot box and to the relay behind the dash. If I ever need to replace the switch, I can drill out the rivets in 30 seconds and remove the entire bracket to get the switch out and a new one in.
Legal: 1/30/2020
You Dog!
Didn't Think Of That One!
Boy, do I miss those days of dimmers on the floor.
Legal: 1/30/2020
Are you going to rivet it in from the firewall side or use rivet nuts in case you ever need to pull it loose?
I'm still undecided. I don't want any water coming in, so it will need to be done in a way that seals well. My experience with these switches is that they are very durable, so I'm willing to risk a difficult replacement. I'm looking at these:
https://www.mcmaster.com/#leak-resis...ivets/=19bd9f3
Legal: 1/30/2020
