I have been dreading trying to do anything with the e-brake assembly, but the time has come to get it done. I ran the cables from the mounting point at the exit of the trans tunnel and then to the calipers.
The cables are touching several parts of the rear suspension and seen like there should be a better way to route them. Am I missing something like some clamps or other management system that would keep them from rubbing?
Also, when the cables are run under the 4" cross tube, do they just rub or is there something I can do to keep them off the chassis. I've looked at some of the over the frame modifications but can't quite visualize how to get the cable ends to the correct location.
