I am looking to buy a couple spares, I cannot recollect who the vendor is that I bought the heat shields from, all I remember is that they also sold heat shields for corvettes.
Help !
Help !
Baghdad Bob
That's a nice looking clamp for your heat shields, when you recall your vender please post.
I'm interested!
Were they from Cobrastuff.com?
HTH
Carl
I found these on McMaster-Carr that are similar less the nutserts:
https://www.mcmaster.com/#5204k15/=19lo2a2
Yes, I think I bought them fromb Cobras tuff but haven't found if they sell the clamps alone. I believe I saw that ********** had the clamps tho.
see link
http://www.**********accessories.com...ld-clamps.aspx
Baghdad Bob
it is Cobrastuff that uses those clamps. The shields cost from $170 plus shipping to $230 plus shipping.
The response I got from Cobrastuff is to buy them from **********. They are $70 for a set of 4 and I only need one. It IS in my garage somewhere.
Baghdad Bob
Looked at the McMaster carr site, the clam I have is stamped with " 84 - 92mm"
if I get a few and a couple rivnuts I should be able to make one up.
Plus I can learn how to use the rivnuts that I order from amazon for other areas on the roadster where some better that an aluminum rived should be. such as the side edges of the console tunnel and the straps I made to make the dash removable and the access panels in the trunk.
the mc part that seems to match up best is....5204K14
https://www.mcmaster.com/#bolt-clamps/=19pkdjz
Baghdad Bob
If the clamps don't open up to allow the use of the typical nutsert tool, you can make a compact tool. Check out this thread:
http://thefactoryfiveforum.com/showt...Nut-sert-tools
