OK so say I want to go back and check the torques on my bolts.
Rear CV axle nut calls for 98 lb-ft and then 45 degrees.
How would you check this after the fact?
Obviously cant put a torque wrench on it to check because I don't know what the initial resulting torque equaled after I did the additional 45 degrees. What do you do in this situation?
