London Cobra Show
Results 1 to 25 of 25
Thread: Factory Five 818 Registry!
    IMPORTANT! DO NOT POST TO THIS THREAD
    Welcome to the Factory Five 818 Registry!
    This is a special forum, which showcases YOUR Factory Five 818!
    There is only one ACCEPTABLE way to post to this forum, and that is to fill out THIS FORM.
    The form is for you to describe YOUR Factory Five Type '65 Coupe.
    This thread is for ALL Factory Five 818s! If you have a build in-progress, that's OK! Just don't put a completion date. All Registry Entries without a completion date will be considered still under construction.
    -->You can and should update your registry entry to add details and PICS.<---
    Warning: posting directly to this thread (not filling out the form) will result in your post being deleted.
    So if you own a Factory Five 818 feel free to fill out THIS FORM and submit it to the Registry!
    Junior Member randy808's Avatar
    Colorado Springs, CO
    Factory Five 818 Registry Entry
    FFR Number
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    TheFactoryFiveForum.com user name of current owner
    Randy808
    Current Owner Name
    Randy Whittington
    Former Owner Names
    State of Completion When Bought
    New Kit from Factory Five
    Color - Body
    Black
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    ''Other'' Engine Displacement
    Transmission
    Other
    ''Other'' Transmission
    Rear Gear Ratio
    Other
    ''Other'' Gear Ratio
    Differential Type
    Limited Slip
    ''Other'' Differential Type
    Rear Suspension Type
    IRS
    Shocks
    Koni Double Adjustible
    ''Other'' Shocks
    Suspension ''Width''
    Standard
    Wheel Size
    18''
    Tire Size - Front
    225
    Tire Size - Rear
    255
    Roll Bar Type
    Custom
    Optional Equipment
    Regional Location of Build
    Northern Mountain US
    Detailed Description of Custom features
    Image Attachments
    Suisun City, CA
    FFR Number
    F5R1000067ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    JeromeS13
    Current Owner Name
    Jerome Silvers
    Former Owner Names
    Color - Body
    White
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5L
    Transmission
    Other
    OEM Subaru 5MT
    Rear Gear Ratio
    Other
    3.70
    Differential Type
    Open
    IRS
    Shocks
    Koni Single Adjustible
    ''Other'' Shocks
    Pin Drive
    Wheel Size
    18''
    Tire Size - Front
    235
    Tire Size - Rear
    265
    Roll Bar Type
    Single Span
    Optional Equipment
    Image Attachments
    Perth Australia
    FFR Number
    F5R0041ERB
    Delivery Date
    Completion Date
    ''Mark''
    Chris Canning
    Current Owner Name
    Chris Canning
    Former Owner Names
    Color - Body
    White gelcoat
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5L
    Transmission
    Other
    5 speed
    Rear Gear Ratio
    Other
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    235
    Tire Size - Rear
    245
    Roll Bar Type
    Single Span
    Optional Equipment
    • Front Splitter
    Australia
    Build will be a pretty standard 818R with all the carbon fibre bits a few stickers and just for a bit of casual fun on the track.
    Purchased a 2012 WRX as a donor and try to use as much of it as we can anyway.
    Spec subject to change as the build goes so will keep you updated.
    Being built in Perth Western Australia as a demonstration car for Component Cars Australia
    Image Attachments
    Bowling Green, KY
    FFR Number
    TBD
    Delivery Date
    &#92;
    Completion Date
    &#92;
    ''Mark''
    Mitch Wright
    Current Owner Name
    Mitch Wright
    Former Owner Names
    Color - Body
    White
    Color - Stripe
    TBD
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.0
    Transmission
    Other
    04 Subaru WRX 5sp
    Rear Gear Ratio
    Other
    Differential Type
    Limited Slip
    Quiffe
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    225
    Tire Size - Rear
    260
    Roll Bar Type
    Custom
    Optional Equipment
    Southeast US
    Image Attachments
    FFR Number
    104
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    jdhearn
    Current Owner Name
    John Hearn
    Former Owner Names
    Color - Body
    White
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Injection
    2.5 NA
    Transmission
    Other
    5 Speed MT
    Rear Gear Ratio
    Other
    3.90
    Differential Type
    Limited Slip
    4-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    16''
    Tire Size - Front
    215
    Tire Size - Rear
    220
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Heater
    • Bumper - Front
    • Bumper - Rear
    • Backup Light
    • Wipers
    • Sun Visors
    Northeast US
    Tires are actually 205-55-16, wasn't available in the pick list. 2002 Outback wagon donor.
    Image Attachments
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    FFR Number
    F5R1000086ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    K3LAG
    Current Owner Name
    Larry Gegel
    Former Owner Names
    Color - Body
    White
    Color - Stripe
    Orange Trim RAL 2008
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.0l
    Transmission
    Other
    Subaru 5 Speed MT
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    215
    Tire Size - Rear
    245
    Roll Bar Type
    Single Span
    Optional Equipment
    Northeast US
    Image Attachments
    Senior Member cmcintyre's Avatar
    Danbury, CT
    FFR Number
    F5R100046ES
    Delivery Date
    Completion Date
    ''Mark''
    cmcintyre
    Current Owner Name
    Christian McIntyre
    Former Owner Names
    Color - Body
    White (or TBD)
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    03 EJ20 2.0L WRX
    Transmission
    Other
    Subaru 5 MT
    Rear Gear Ratio
    Other
    3.70
    Differential Type
    Open
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    225
    Tire Size - Rear
    245
    Roll Bar Type
    Single Span
    Optional Equipment
    • Heater
    • Front Splitter
    • Wipers
    Northeast US
    Very Cool Parts Shifter Kit, adjustable rear lateral links, street rear spoiler, cat less up pipe, Gimmick Silicone Turbo Inlet. Planned - ZeroDBmotorsports CNC Oil Cap and Fill tube, Coolant tank relo bracket. Everson Master Cylinder flange; Soft top, Boyd Tank (maybe), Vintage Air Heater, Wipers (when developed), Cool Air Intake, EFILogics Dyno Tune, shooting for 240rwhp CT Emissions legal.
    Image Attachments
    Senior Member TrickyPete's Avatar
    Lewiston ME
    FFR Number
    314
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Trickypete
    Current Owner Name
    Peter Desjardins
    Former Owner Names
    Color - Body
    Red
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Injection
    2.5
    Transmission
    Other
    5speed subaru
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    225
    Tire Size - Rear
    225
    Roll Bar Type
    Single Span
    Optional Equipment
    • Radio
    Northeast US
    Image Attachments
    FFR Number
    095435
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    dhpointer
    Current Owner Name
    Davd Pointer
    Former Owner Names
    Color - Body
    Yellow
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5ltr
    Transmission
    Other
    Subaru 5sp
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    215
    Tire Size - Rear
    235
    Roll Bar Type
    Single Span
    Optional Equipment
    • iPOD/MP3 Player
    • AC
    Image Attachments
    Senior Member Junty's Avatar
    Dec 2013
    New Zealand
    FFR Number
    F5R000131ESB
    Delivery Date
    &#92;
    Completion Date
    &#92;
    ''Mark''
    junty
    Current Owner Name
    Justin Walker
    Former Owner Names
    Color - Body
    White - eventually intend on wrap...
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5l
    Transmission
    Other
    WRX 5 speed
    Rear Gear Ratio
    3.73
    Stadard for WRX
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    215
    Tire Size - Rear
    255
    Roll Bar Type
    Single Span
    Optional Equipment
    • Backup Light
    • Custom Mirrors
    • Wipers
    • Sun Visors
    Australia
    Question above - I had to include 'Australia' for region - however I'm actually located in New Zealand...
    http://thefactoryfiveforum.com/showt...S-build-thread
    • Donor 2004 Subaru WRX sedan (NA 2.0L)
    • Brakes 2008 WRX 4 pot front 2 pot rear (eventually adding 4 pot to rear)
    • Keeping Subaru ABS - using this for traction control sensors via MoTec M800 ECU
    • Lower front aluminum control arms
    • Cusco LSD
    • XXR 18 x 9 rear 17 x 8 front with Toyo R888 (thanks Wayne VCP)
    • VCP rear trailing arms
    • New adjustable rear lateral arms
    • New CV joints, Boots, Clutch, Brake Pads and Disks, Bearings, Tie rods… (Every thing new)
    • Nissan 1.5 x 12mm wheel studs (about 10mm longer than Subaru) and taller pitch thread
    • MoTec ECU, with traction control, cruise control, Drive by wire included in MoTec is anti lag, boost control and dual AVCS valve control.
    • TGV delete kit
    • Paint, Wrap, TBD – perhaps to be controlled by budget?
    • AWIC - custom fabrication
    • Intention is get the vehicle street legal and registered, then play…
    Finished build Jan/Feb 2014, however I've been required to make small additional modifications to complete the certification process in New Zealand. The car has actually been at the compliance centre/engineer since February 2014 - I trust and hope to get finished, complied and registered car back within next fortnight (end May2015).
    This 818S RHD road car has been tuned at 12PSI boost and standard pump fuel producing 247KW at rear wheels. So with Motec ECU we have a lot of room for boosting the performance to extreme :-) This 818S also has full functioning Subaru ABS system - although we intend upon increasing the rear brake size soon...
    Image Attachments
    Senior Member AZPete's Avatar
    FFR Number
    F5R1000025ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    AZPete
    Current Owner Name
    Peter Hildt
    Former Owner Names
    Color - Body
    white gel coat
    Color - Stripe
    no stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5 L
    Transmission
    Other
    5MT
    Rear Gear Ratio
    3.27
    Differential Type
    Open
    OE transaxle
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    215
    Tire Size - Rear
    245
    Roll Bar Type
    Single Span
    Optional Equipment
    • Power Steering
    • Radio
    • iPOD/MP3 Player
    • Heater
    • AC
    • Backup Light
    • Front Splitter
    • Custom Mirrors
    • Glove Box
    • Wipers
    • Custom dash
    Southern Mountain US
    Image Attachments
    Senior Member Loring's Avatar
    Nov 2015
    Lakeland, FL
    FFR Number
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Loring
    Current Owner Name
    Loring
    Former Owner Names
    Color - Body
    TBD
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5L
    Transmission
    Other
    Subaru 5MT
    Rear Gear Ratio
    Other
    4.444
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    19''
    Tire Size - Front
    245
    Tire Size - Rear
    285
    Roll Bar Type
    Single Span
    Optional Equipment
    • Wipers
    Southeast US
    Image Attachments
    San Diego Ca 92106
    FFR Number
    F5r1000253es
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Flynntuna
    Current Owner Name
    George Neves
    Former Owner Names
    Tim Treat ( FFR forum name TahoeTim)
    Partially Built (Not the Original Purchaser)
    Color - Body
    Red gelcoat
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Injection
    3.6lt
    Transmission
    Other
    Subaru 5 sp
    Rear Gear Ratio
    Other
    4.44
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    215
    Tire Size - Rear
    255
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Radio
    • Foot Box Vents
    • Front Splitter
    • Custom Mirrors
    • Custom dash
    SoCal US
    Image Attachments
    Oklahoma City
    FFR Number
    F5R1000429ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    fastzrex
    Current Owner Name
    Mark A. Fulton
    Former Owner Names
    Color - Body
    Black - Final, currently Red as delivered
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5 Liter
    Transmission
    Other
    5 Speed Subaru
    Rear Gear Ratio
    Other
    4.11
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    225
    Tire Size - Rear
    245
    Roll Bar Type
    Custom
    Optional Equipment
    • Heater
    • AC
    South Central US
    Image Attachments
    May 2016
    FFR Number
    432
    Delivery Date
    &#92;
    Completion Date
    &#92;
    ''Mark''
    Socalk1000
    Current Owner Name
    Adam
    Former Owner Names
    Color - Body
    Sunset orange
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.0L
    Transmission
    Other
    5 Speed
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    215
    Tire Size - Rear
    255
    Roll Bar Type
    None
    Optional Equipment
    • iPOD/MP3 Player
    • Front Splitter
    • Custom Mirrors
    SoCal US
    Image Attachments
    Charm City
    FFR Number
    119057
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Biknman
    Current Owner Name
    David Potter
    Former Owner Names
    N/a
    Color - Body
    Red
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.7l
    Transmission
    Other
    JDM ver 4 STI 5sp 4:44
    Rear Gear Ratio
    Other
    4.44
    Differential Type
    Limited Slip
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    16''
    Tire Size - Front
    275
    Tire Size - Rear
    295
    Roll Bar Type
    Double Hoop
    Optional Equipment
    • Front Splitter
    Northeast US
    Image Attachments
    Mar 2017
    West Phoenix
    FFR Number
    222
    Delivery Date
    &#92;
    Completion Date
    &#92;
    ''Mark''
    mac1
    Current Owner Name
    Michael C.
    Former Owner Names
    Matteo92665
    Car Was Complete
    Color - Body
    gel coat white
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    EJ25
    Transmission
    Other
    5psd
    Rear Gear Ratio
    4.10
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    225
    Tire Size - Rear
    235
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • iPOD/MP3 Player
    • Front Splitter
    Image Attachments
    FFR Number
    f5r1000267es
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Joe B
    Current Owner Name
    Joseph Block
    Former Owner Names
    John Clark
    Color - Body
    red
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5
    Transmission
    Other
    Subaru MT5
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    225
    Tire Size - Rear
    225
    Roll Bar Type
    Single Span
    Optional Equipment
    Northern Central US
    Image Attachments
    Mar 2020
    Braintree MA
    FFR Number
    Delivery Date
    Completion Date
    ''Mark''
    jbs72697
    Current Owner Name
    Judd Smith
    Former Owner Names
    Color - Body
    Undecided
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Injection
    2.0L
    Transmission
    Other
    5sp man
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    16''
    Tire Size - Front
    215
    Tire Size - Rear
    220
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Radio
    • Wipers
    Northeast US
    Image Attachments
    Mar 2021
    SE WI Kettle Moraine
    FFR Number
    FSR1000291ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    J R Jones
    Current Owner Name
    jim jones
    Former Owner Names
    1) Paul Pocock
    2) Steve Greenhill
    Color - Body
    red gelcoat
    Color - Stripe
    N/A
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.0
    Transmission
    Other
    5-speed Subaru transaxle
    Rear Gear Ratio
    Other
    3.9
    Differential Type
    Limited Slip
    4-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    215
    Tire Size - Rear
    235
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Wipers
    Northern Central US
    Image Attachments
    Senior Member DSR-3's Avatar
    San Jose, CA
    FFR Number
    F5R1000332ES
    Delivery Date
    Completion Date
    ''Mark''
    DSR-3
    Current Owner Name
    Eric L.
    Former Owner Names
    Color - Body
    Black, straight black?
    Color - Stripe
    none
    Engine Displacement
    Other
    Engine Induction
    Injection
    3.0L H6
    Transmission
    Other
    WRX 5MT
    Rear Gear Ratio
    Other
    Differential Type
    Torson
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    18''
    Tire Size - Front
    215
    Tire Size - Rear
    255
    Roll Bar Type
    Single Span
    Optional Equipment
    • Front Splitter
    • Custom Mirrors
    • Custom dash
    NorCal US
    FFR Number
    F5R1000510ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Hronald395
    Current Owner Name
    Ronald Hopkins
    Former Owner Names
    Color - Body
    Red
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.5l
    Transmission
    Other
    5spd Subaru
    Rear Gear Ratio
    Other
    Differential Type
    Open
    IRS
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    250
    Tire Size - Rear
    230
    Roll Bar Type
    Single Hoop
    Optional Equipment
    • Front Splitter
    • Wipers
    Southeast US
    Image Attachments
    FFR Number
    F5R1000431ES
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Steve57
    Current Owner Name
    Steve Sirois
    Former Owner Names
    Color - Body
    factory five stock red
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Turbo
    2.2
    Transmission
    Other
    stock Subaru 5 speed manual
    Rear Gear Ratio
    Other
    unknown
    Differential Type
    Limited Slip
    3-Link
    Shocks
    ''Other'' Shocks
    Standard
    Wheel Size
    17''
    Tire Size - Front
    225
    Tire Size - Rear
    255
    Roll Bar Type
    Single Span
    Optional Equipment
    • Trunk Box
    • Wipers
    Northeast US
    Image Attachments
    Sep 2015
    Hamersville, Ohio
    FFR Number
    361
    Delivery Date
    &#92;
    Completion Date
    ''Mark''
    Lance Corsi
    Current Owner Name
    Lance Corsi
    Former Owner Names
    Color - Body
    Red
    Color - Stripe
    Engine Displacement
    Other
    Engine Induction
    Injection
    2.0
    Transmission
    Other
    5 sp subie
    Rear Gear Ratio
    Other
    390
    Differential Type
    Torson
    IRS
    Shocks
    Other
    ''Other'' Shocks
    QA-1
    Standard
    Wheel Size
    17''
    Tire Size - Front
    245
    Tire Size - Rear
    275
    Roll Bar Type
    Custom
    Optional Equipment
    • Radio
    • Heater
    • Foot Box Vents
    • Bumper - Front
    • Bumper - Rear
    • Front Splitter
    • Glove Box
    • Wipers
    • Custom dash
    • Sun Visors
    Southeast US
    Image Attachments
