SelectivePC
Need to do a bit of research on the oil pan and pick-up sets the other guys are using, and also the motor mount situation, as the used motor company pulled or motor mount brackets and mounts. *******s.
I have seen a lot of the Moroso's used, but don't know if there is a difference in them. So time to start googleing.
The Moroso setup everyone is using with the Coyote is a Moroso 20570 pan with Moroso 24570 pickup. I'm not aware of another brand option, although maybe there is one.
For motor and transmission mounts, the common setup is the Energy Suspension 4.1127G 4.6L Mustang Motor Mounts and the Energy Suspension 4.1104G Transmission Mount. You'll want to add the 1/2-inch spacers that Factory Five makes for inside the motor mounts. Part of their Coyote installation package. But available separately.
Couple of other points. Looks like an F150 Coyote? That oil filter orientation is different than the Mustang, and as I recall that's one of the differences. Regardless, the oil cooler won't fit and probably you'll need to turn the oil filter or use a remote. Also, since you do have an older kit, I'm assuming you still have the older style footbox aluminum? A lot has changed since then for Coyote installations. Factory Five used to use sheet metal that also was for the older 4.6 mod motor. But it's an interference fit for the Coyote unless you tip the engine over, plus it takes a big bite out of the footbox space. There is newer sheet metal that fixes both. Gives room for the Coyote plus restores the lost footbox space. This was recently discussed in another forum post, so maybe you saw that or already knew about it.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
edwardb
Yes it it out of a 2014 F150, and we will be doing a remote filter and removing that awkward filter housing mount. Thank you for the part numbers, and ill be giving FFR a call about the foot panels, I haven't really looked into the panels yet, but i can already tell its going to be a tight fit. That part number for the trans mount will work with the TKO trans?
SelectivePC
Yes. Same one used on my previous TKO builds and now T-56 build. FYI, Factory Five does use an extension plate for the TKO when used with a Coyote in the Roadster. Moves the mount back since the Coyote is a bit shorter than other engines. Visible in this picture if you zoom in on the transmission mount area:
For the footbox sheet metal, just an encouragement to also consider the footbox space in addition to the engine space. The new sheetmetal addresses both. This picture shows a Coyote build with the previous mod motor sheet metal. Note how it was necessary to tip the accelerator pedal over plus narrow the clutch pedal. It's still really tight even with these changes. The new sheetmetal gives a couple inches of space in the area of the accelerator pedal, and it makes a huge difference. I wasn't going to do a Coyote build until this was addressed. After driving two previous SBF builds I wasn't willing to live with less space in an already tight area.
Build Thread and
Video.
Build Thread and
Video
edwardb
Ok, I am running a standard cable driven throttle body, so i'm retaining the stock pedal the kit came with, and running the cable that comes in the throttle body kit. Using the Holley EFI system and completely getting rid of the factory pedal BS, so foot room shouldn't be to bad in there.
I will however need to call them about that mount spacer, or make one
SelectivePC
A traditional accelerator pedal vs. the Coyote DBW module doesn't have any bearing on available footspace. If you were to see the old vs. newer sheet metal side-by-side you would see the difference. Good luck whatever you decide.
Build Thread and
Video.
Build Thread and
Video
edwardb
I'm not against it at all, I mean if it works and frees up some foot box space and doesn't have too much of a FFR tax attached to the price lol, im all for it. Ill have to call them in the AM, didn't get around too it was busy installing a bad *** hand me down from a customer. See next post.
SelectivePC
On a side note, has anyone left the FPR (fuel pressure regulator) towards the rear of the car near the tank, or as close to the motor as possible like usual. Only reason I ask, is because the newer mustangs (5.0 based) have a in tank, (in pump actually) regulator. I may be over thinking it, but I was thinking of just running one single line to the front for a feed instead of a feed and return, and leave the FPR more towards the tank area?? Any input would be great. Thanks guys.
I've noticed a number of Coyote builds using a fixed pressure regulator/filter near the tank with a short return line and only running the single supply line to the engine compartment with excellent results. Breeze sells a kit that uses (I believe) this particular regulator. http://www.breezeautomotive.com/deta...p?prod_id=1185. I did my Coyote Roadster with 3/8-inch supply and return lines to the engine compartment, and doing the same with the Coupe build. Just finishing them up today. I'm kind of stuck on having the pressure adjustable and also prefer to regulate the pressure at the end of the line not at the beginning. But I'm not an expert in fluid mechanics (hardly...) so can't say whether the difference is worth talking about. I'm sure either way is fine. BTW, I wouldn't draw too many comparisons to the Mustang fuel delivery system. It may have a return line to the tank (I really don't know...) but the Mustang by definition is a returnless system. The fuel pump running and resultant pressure is controlled by the PCM. For the crate Coyote, Ford changed this to a return system where the pump runs wide open all the time and the excess fuel is returned to the tank.
Build Thread and
Video.
Build Thread and
Video
edwardb
Good enough for me, sounds like ill be running both lines which i'm fine with, just a wondering mind
Got the motor all painted up. Cute little blue berry.
Now for some more powder coating and we will be getting a first fitment of the motor in, too see what we are going to be doing about headers. Again having a different approach to the build. Wanting to go against the grain and not use the usual side exit exhaust. Time will tell though, may end up changing it.
That painted block is going to look great. If I had it to do over....
Straversi
I was a little worried about it at the start, but its growing on me.
