I used a Moser M88 rear end and it has 3" thick wall tubes. The stock ford 8.8 axle tubes are smaller then 3". you may want to measure the Moser axle tubes to see what size you have. Also Moser should have welded the bracket to the axle. If they did not call them and they should fix it.
