As title says. To minimize the slosh?
'33 Hot Rod
MK4 Roadster
I'm not a racer, so I'm probably off the mark; but I don't "get it". I was under the impression fuel cell foam surrounds an inner bladder, filled with fuel, correct? And it's use is to absorbs the shock from a crash and not ignite the fuel. Re: the '33 tank I think if you want to reduce sloshing you would put baffles in the tank, not foam?
It's the opposite according to all I've found.
And, this over baffles for one reason only. Easier than getting baffles into it lol.
Edit: after looking around, box the idea. It seems many have issues with foam plugging the lines. I'd rather not have to pull the tank, especially considering location, because of foam
Maybe I'll look at changing the tank shape so it goes in from the back and then add some baffles while one end is off.
'33 Hot Rod
MK4 Roadster
Yeah like I said, I'm not a racer and have never actually used one. Still learning all the time!
Back to your question, I'm thinking if it COULD be done, wouldn't it reduce the capacity significantly? I'm also thinking that since these things I believe are certified and have an active shelf life (I think I read 5 years once) you probably would be better off getting an ACTUAL fuel cell over trying to fab your own.
I'll back out now and let the experts chime in...
I've messed with that foam before and it compresses pretty small. The capacity loss should actually be minimal. But like I said, I don't want the possibility of trash from it like I've read. Actually read that some guys have to clean their tanks fairly regularly! I think this is a case of where a race type part isn't suitable for street.
Was just a though though. Was just trying to get some baffleage (is that a word?) without springing for a new tank.
'33 Hot Rod
MK4 Roadster
Have you thought about going with a Hydramat? https://www.holley.com/products/fuel_systems/hydramat/
Here is mine...
Or just cut the top of the tank and tack in a couple of baffles.
In 818ramus's build he used wiffle balls to keep the sloshing down. http://thefactoryfiveforum.com/showt...odified/page18
We remove the foam from our dragsters fuel cell when we run alcohol for fuel. The alcohol will cause the foam to come apart, I wonder if the alcohol in todays gasoline would have the same effect?
CVOBill
'33 Hot Rod
MK4 Roadster
Most racing alcohol fuels are Methanol.
Wirenut, is yours installed in the standard tank with the standard pickup? What did you use to connect between the mat and pickup? As I have been driving mine, I am noticing it bogging and stuttering after a hard brake which makes me think I am losing fuel due to sloshing.
Also, where in Houston are you?
I think you'd have trouble getting the foam blocks into the tank and all positioned correctly. Fuel cells have a larger access opening than a typical sending unit provides. The blocks are a specific size and shape to fit the tank and clear the sending unit.
As stated above, alcohol will kill fuel cell foam designed for gasoline. Here in Northern AZ we have up to 10% alcohol in our gas and so far my foam has held up. If you have more alky in your gas than E10 that may be a problem.
There there's the safety aspect you better be aware of before playing with foam blocks. If you've had fuel in the tank you must drain ALL the fuel and flush the tank with water before inserting and removing foam. The foam can generate enough static electricity to cause a spark and that can be a very bad thing if there are fuel vapors present.
Just to clarify.... Alcohol racing fuels are Methanol (very reactive, poisonous). The alcohol usually mixed with pump gas is Ethanol (fairly inert, not poisonous). Methanol eats everything including fuel cell foam, while ethanol only breaks down certain rubbers but not fuel cell foam.
I prefer my ethanol in Bourbon form, not as government subsidized pump gas.
I have a 56 Chevy pickup that I built between 1993 and 95. I used a race type foam filled fuel cell in it when I built it and drove it all over the western U.S. without issues until 2010 when I moved to Arizona. I left my truck in storage in Idaho for a year and a half before bringing it to Arizona. When I got it here I had a lot of trouble with the foam in the tank disintegrating and plugging the fuel system. I finally removed the existing cell and replaced it with a new one of the same type and did not have any more trouble. I have since replaced the entire fuel system including the tank because I am now running a fuel injected engine. In any event, my experience was that as long as I drove the truck regularly I was fine. Once I let it sit for a prolonged period I had trouble with the foam. My 2 cents worth.
You do have to be careful with sourcing fuel cell foam as some of it will degrade even with just racing gas. Everything will appear okay but you'll start finding waxy deposits in carb internal passages causing mixture problems. Just a word of caution.
FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
