Results 1 to 10 of 10
Thread: Brake Vent Screens
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Brake Vent Screens
    Got vents from Finish Line and they look way too big. I thought they went inside the openings, these are even too big for the lip on the backside of the opening? How do you attach them?
    Senior Member Norm B's Avatar
    They fit over the body openings from the back side. I trimmed mine so the screen was flat against the back of the opening and used silicone to attach.
    HTH
    Norm
    Longmeadow, MA
    Thanks Norm, I'll give it a shot..
    I just did the same but have not updated my build thread.
    I trimmed the plastic piece to make it fit better but the screen still didn't look right so then I put the screen on the back side of the vent and shaped it and trimmed it more aggressively. Once I got the screen the way I wanted it I cut the plastic piece more to fit. I plan to glue/silicon this in place. I used a golf ball to push the screen forward and get that rounded shape. I looked at lots of photos I have and noticed that most screens fit flat but some had shaped them with some curvature. Hadn't ever noticed it before. Personal preference.
    Hope that helps
    Jupiter, FL
    I might be just cheap, but isn't this the same metal mesh people use to lay tiles? I have seen something like this in HomeDepot.
    Could be. I bought the Finish Line kit because the plastic scoop (not shown) that fits behind the screen funnels the air to the ducts used for the foot box fans. If you are not installing foot box fans, then you could try any aluminum screen.
    Whatever you do, do it before paint if possible. I was pressing up against the body pretty hard to get theses shaped.
    Jupiter, FL
    Will do. I was told by Jeff that the car should 100% done before the paint job.
    I am not using the scoops, only to cover the openings.
    Senior Member RickP's Avatar
    Boyertown, PA
    anyone have Mark Reynolds (Breeze) screens installed?
    Senior Member DavidW's Avatar
    Stevensville, MD
    Yes they are!
    Not yet, I fit them in place and they do fit good. I haven't installed them yet because I cant get over the fact I used the same material as a backer when I parged my foundation block on my first house.
    I may use these as a template and get some other material, a quick look on the interwebs and found customcargrills.com, maybe the grill material for the Mustang would look better.
    St. Louis, MO
    I used 3M HSRF to bond my screens in place. They are still good as new 10 years later.
