Results 1 to 31 of 31
Thread: Paint with Body ON or Body OFF?
    Member JRD56's Avatar
    Oct 2014
    Olathe, KS
    I'm nearly ready to paint my roadster body. All body work is done and I'll be doing the final wet sand shortly. I've read thru a lot of threads but still can't decide whether to paint it with the body on or body off. Currently the body is off and it will certainly be easier to paint that way. I do have a paint booth with enough room to paint the body on the body buck, lay the hood and trunk flat on stands, and paint the doors mounted on a stand vertically so I get to all sides. So I can do all components at the same time.
    I'll be painting it with a metallic paint (Viking Blue) and non-metallic white stripes. Base coat/clear coat. It seems the preference is to paint with the hood, doors and trunk installed to ensure the metallic paint looks consistent when finished and in the sun. However, it also seems many are not painted that way and turn out fine. I'm hoping to get opinions based on others experience.
    If I do paint with the components installed, do I paint the jams first and what is the best way to do that?
    Lastly, what is the best way to do the stripes? I don't want to feel the transition between the blue and white when its all complete. I realize that entails some extra work wet sanding the clear, but is it best to spray the white, tape the stripes and then blue. Or do the whole thing in blue then tape and paint the the white stripes.
    Thanks in advance for any comments.
    Purchased and un-assembled Mk3 in 2016. 5.0, Aluminum heads, Performer RPM Air gap, Quick Fuel 650 carb, BBK headers T5, 3.55 rear solid axle, Koni Shocks, PS with Hydra-boost. Also own two restored vintage Mustangs, two Model A fords, 1941 Chevy truck and several other hot rods.
    From what I have noticed in body work threads, some of the guys build stands to hold the hood, trunk lid, and doors, in the same orientation they would be on the car. The hood and deck lid could be painted underside first, dry and then flip over since you can't really see both sides at the same time in case there is a slight difference. Having the doors on a stand that mounts to the hinge studs lets you paint both inside and outside at the same time which is good because that top 5 inches or so of door is readily visible inside and out. I will let those w/ a lot more experience than I have chime in on your other questions.
    Body off with the moving panels in their installed orientation. I posted some info and photos a while back showing my stands for the doors, hood and trunk lid which allow them to be turned without having to wait for drying so that everything can be sprayed in the same session.
    https://thefactoryfiveforum.com/show...t=contraptions
    You may have to do the Photobucket fix to see the photos:
    PHOTOBUCKET FIX
    Oct 2014
    Olathe, KS
    Craig and Jeff, thanks for the quick replies.
    Jeff, I did build your "flip flops" based on the reference Srobinsonx2 made in his infamous body build thread. They've work great to this point. However, they will not fit in the booth with everything else if I go with body off. So I may spray the underside of the hood and trunk so they will fit in the booth with the body and doors.
    Craig, I did mount the doors as you described. I did modify them after the first time I sprayed primer. They now are at a slight angle which allows better access to the front edges while spraying.
    Oct 2014
    Olathe, KS
    And Jeff, God bless you for posting the photobucket fix, I've been trying to figure that out. It worked fine.
    Jim
    PHOTOBUCKET FIX
    You're such a helpful guy Jeff!
    Chino Valley, Arizona
    He’s “The Man” - for every direct answer/guidance he provides, dozens of Forum members indirectly benefit!
    Jax Beach, FL
    I have only done one, but here is my two cents.
    Body off.
    All panels in their correct orientation, but not on the car.
    Paint the stripe color first. This way you only mask off the stripes. The other way, you have to mask the entire car.
    Stripe layout is more art than science. The car is not symmetrical, so measurements will not be spot on. Remember that the stripes don't need to BE straight, they need to LOOK straight. You may have to fudge a bit to get them to hit the visual queue areas so they look correct.
    I used Jeff's contraptions. They worked great.
    With 3 coats of clear, there is plenty of meat to sand the stripe transition out.
    The most important advice that I can give you is DO WHAT KLEINER AND DaBAT SAY.
    A booth. That is serious luxury. Good luck!!!
    OFF...da Bat
    No votes for "body on" paint job ? Hard to believe.
    Oct 2014
    Olathe, KS
    Well if the Jeffs say body on then body on it is. I'll be painting this weekend. Thanks for all the reply's.
    Quote Originally Posted by JRD56 View Post
    Except we didn't say body on
    Oct 2014
    Olathe, KS
    OOPS, meant body off. I spent yesterday brewing beer with a group of friends. Perhaps I sampled a few too many...........
    In that case you're excused
    Lol...
    WHAT ! ...WHAT IS HAPPENING HERE !!!......This is stressing me out ! gonna need some of that "home brew".
    I think what is happening is people don't understand everything they read. Maybe if the print is larger it will make sense. And a bright color too.
    Body off
    Mar 2017
    columbus ohio
    Body Off, otherwise too many things in the way.
    Body off
    Rich, Brother....you are in the ballpark.....ONE MORE TIME BUT WITH "FEELING"....and I swear to god if you ask me "what's my motivation "one more time, I will pull over and make you walk home !...da Bat
    Mark Eaton's Avatar
    Medford, Oregon
    So... You guys are saying BODY OFF??
    Your going to send Miller into rehab...one shot of rum too many...it’s like an alcoholic induced vapor lock...
    Mark Eaton's Avatar
    Medford, Oregon
    No worries I'll get him out of rehab when I show up to HB this weekend. I just hope there are some extablishments in the area that serve adult beverages because I'm going to need a few after the week I have ahead of me! Its not a dry county or anything is it!?
    Mark
    Well if it is a dry county, for the first time ever(), California now has medicinal herbs.
    Oct 2014
    Olathe, KS
    Body OFF
    Paint ON
    Got the color and clear coat on today. I'm going to wait a few days, have a home-brew then wet sand, cut & Polish. Not really looking forward to that..........
    Fairfax Station VA
    Body OFF
    Paint ON
    Is that Viking Blue with Wimbledon White stripes?
    MK IV Roadster #8631
    There ya' go
    Looks like Guardsman and Wimbledon but lighting may be playing with that.
    Oct 2014
    Olathe, KS
    Its very close to Viking Blue, but is actually Antigua Blue, which is a 1999 Land Rover Discovery color. When I looked at the paint chips side by side, I liked Antigua better. Beauty is in the eye's of the beholder as they say. The stripes are Wimbledon White.
    JRD-
    Love the color; very nicely done!! I look forward to seeing more as you wrap it up.
    Fairfax Station VA
    I love that color too. Do you happen to have a paint code (Land Rover or other) for Antigua Blue?
    Oct 2014
    Olathe, KS
    The paint code is 645, JFN. PPG # is 191204. I'm using Matrix which is # 191099. Here is a better picture of it out in the Sun.
    Fairfax Station VA
    Thanks very much!
