Thanks, JMan! I looked at the block today, and there's the threaded hole right where you said it was. That answers two questions: where does the oil pressure switch go? and what's THAT hole for?
I noticed there's a similar hole on the passenger side also. I haven't inspected it closely to see if it's a blind hole or if it goes into something like an oil passage or water jacket. Do you know what that hole on the passenger side (circled in red) is for?
