Results 1 to 6 of 6
Thread: Wiring with the RT turn signal and the VW relay
    On a roll Al_C's Avatar
    Wheaton, IL
    JDAV had a really good write-up on this topic last year, but he's using an extra relay. Hopefully, I only need one. You decide. So here's the situation: I'm installing the RT turn signal as I write this. I'm a bit at a loss connecting the VW relay. Please check out the photos here, too. Based on JDAV's posting last year, I connected the Ron Francis Headlight dimmer switch wire to post 56. The RF brown high beam wires went to 56a; the RF red low beam wire went to 56b. That leaves post 30 and post s.
    The premise is that I'm using the VW relay so I can dim the headlights with the stalk button. I don't care about flash to pass. So...
    1. what goes on post 30? one of the leads from the stalk switch?
    2. what goes on post S? the other lead? Or something else?
    Here are my photos:
    I look forward to your ideas here!
    Senior Member Jdav's Avatar
    ATL GA
    Al, mine is set up to use the push button to switch from low to high beams, not as a momentary flash to pass. I’m not exactly sure what you mean by “dim the headlights “
    MK4 #9028 - Coyote - TKO600
    Wheaton, IL
    Yes. The goal is to push the button so the headlights toggle from low to high and vice versa.
    Lost Wages, Nevada
    While I personally am NOT using this circuit in my MK II, I can tell you that the #30 spade is power for the lights, either in Hi or Lo position.
    Circuit is 12V power in to #30 --> out 56a to Lo (or Hi) --> headlight grounded. Out 56b to Hi (or Lo) --> headlight grounded. Looks like "S" is from the flasher which is also grounded.
    As soon as I can find the VW Relay circuit posted on here, I'll figure out where the rest go . . . and post again.
    Others may beat me to it
    Doc
    Prairieville, LA
    Just finished installing it this week. I used 2 relays since I wanted the "flash to pass" feature. If you don't want the "flash to pass" feature, then you only need 1 relay which is the VW latching relay. This is how you would hook up the one relay:
    LT BLU-HDLT SW-DIM SW wire that comes from the headlight switch thru the Dash Harness is connected to terminals 56 and 30 on the VW relay. The BRN-HIGH BEAM wire connects to terminal 56A and the RED-LOW BEAM wire connects to terminal 56B. The terminal S connects to one of the wires on the RT stalk switch (no need for diode if using 1 relay). The other wire on the RT stalk switch is connected to ground. So when you press the stalk switch, it will toggle between High and Low beam.
    MK4 #9237 - complete kit, Coyote, TKO600, IRS - Delivered 12/11/17
    Wheaton, IL
    Thanks, gentlemen! I'll give it a whirl!
