Thread: Forum Speed Is Rocking, But I'm Getting The Attached Warnings:
    Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_postbit.php on line 1033
    Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
    Senior Member shark92651's Avatar
    Feb 2018
    Frisco, TX
    Me too. I saw them as soon as I logged in tonight. They were all stacked up above the blue header of the main page.
    Suggest you search all the source and replace "preg_replace() with "preg_replace_callback"
    We're in the throws of analysis, fixes and migrations. Stay tuned.
    https://thefactoryfiveforum.com/show...743-Forum-slow
    Thanks Super Dave,
    It looks like you guys are Kicking Asphalt & Taking No Prisoners!
    Good Luck From The Camp Granny!
    mburger's Avatar
    Punta Gorda FL
    Exciting!!!!
    Mark
    Senior Member 42Bfast's Avatar
    Feb 2017
    Pensacola
    Sounds very similar to changing the spark plugs while running 70mph down the interstate! ��
