I have a 11-14 Coyote with starter included. I have a hot from the battery to the outside large terminal on the starter. I have 3 red wires in one harness and from reading, it seems they go on the same terminal as the battery feed.
I have a light blue wire that can go to the small terminal or I have a tan w green tracer labeled starter solenoid run with a black wire labeled ground that I can use.
Using the FFR wiring schematic, Rev N, it shows the light blue going to the small terminal and a black unlabled on the inside large terminal.
If the blue is the right solenoid activation wire, where does the tan w green tracer go?
Do I need to attach the black running with tan w green tracer to a ground or the larger terminal on the starter.
Do I need to run a ground from the inside large lug on starter to the grounded engine, grounded frame, or battery ground.
For information, I have the positive battery run through a disconnect switch then to the outside larger starter terminal.
I have the battery ground run to the bell housing bolt and then to the frame.
